SBC 283 forged pistons
Re: SBC 283 forged pistons
Jack I just want to thank you for sharing a part of your past. I would almost like to see a section where posters
Could share their history.
I really like reading these kind of posts of people's history. Brings back good memories of my own past.
I didn't type everything out, basically I wanted to see if the fella was willing to bore it and if he was, I would suggest a 327 small journal block that could easily go 4.030" and it would accept his shorter stroke crankshaft! I don't doubt that at all about the 301 Packard,,, They need to be sonic checked and if ok be poured with Hardblok and get machined. That's why my big bore motor is in a Dart Little M block (due to the bore being 4.155" x 3.260" stroke)PackardV8 wrote: ↑Thu Dec 12, 2019 11:21 amYou guys build 'em your way, but experience taught me fifty years ago not to bore a full-race 283" to 4.00". Cylinder wall strength is even more important on a boosted application .Pursue if the block could go to 4 inches. That would open up some options for you and the extra cubic inches wouldn't hurt either.
Old guy story follows, so you young guys can ignore if you choose:
In the early 1960s, I was a high school kid washing parts for Bobby Allison the years he was National Modified Champion. He was running a 301" with Jahns forged 13:1 popups, a Chet Herbert roller cam with the square key stock bar through the oil galleries to keep them aligned and Jackson IR injection. Racing four times a week, Huntsville on Thursday, Midfield on Friday, Montgomery on Saturday and Sunday afternoon at the fairgrounds in Birmingham, eventually the 301" let go one Saturday night. Since Tom Gloor owned the Chevrolet dealership and promoted the Birmingham races, Bobby called Tom, who called his Parts Manager, who met us at the dealership dark-early Sunday morning. He pulled a '61 Corvette short block off the shelf and we installed the cam and top end right there in the dealership and went to the race. With fewer inches, less compression, but better wall strength, the fresh 283" standard bore was as fast as the 301" had been.
www.autotransdesign.com www.gzmotorsports.com
www.cranecams.com www.prosystemsracing.com
www.hardblok.com
Please say a prayer for all that serve and gave all to serve this Holiday and everyday!
www.hardblok.com
- BrazilianZ28Camaro
Thanks for the good ideas and tips Gents!
Just to remember, SBC blocks are rare overhere in Brazil, and parts are nuts expensive due the taxes.
The block in question is a STD bore, but a few cylinders are corroded and may clean at sixty over, I'm still waiting for it for measure the bores and sonic measure the cylinder walls.
I thought about the 4" bore route for the better piston choice, but I'm not so inclined to, because that would be the last block possible bore size, meaning if it clean at sixty over, we'd have another overbore available in the future (080 or 4" ).
Yes, I talked about my customer to consider the Hyper pistons, and yes, this is a low boost application, maybe 450 HP on pump gas.
The L6 FTs forged Opala pistons we have available here would need to have the valve reliefs cut by a lot and that would be risky.
I'll take a look on the Wiseco web catalog.
Thanks everybody for replies!
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
1.38 60' / 4.05 330' / 6.32@111.25mph
NEW BEST ET
I’ve got a set of L2209A. Stock bore 302 (I think) they measure 3.955
Dave Cunningham/ Woodruff Carburetor Specialties
Carburetorrestorationyoungstownoh.com
Regular (E25) cost is 4.50 Reais a Liter, or 3.97 USD a gallon.econo racer wrote: ↑Sun Dec 15, 2019 3:31 am My friend how much does regular gas cost and how much for race gas?
Our best pump gas can be compared with race gas and cost about 6USD a gallon.
NEW BEST ET
NEW BEST ET
Thanks for the link, I'll take a look.
NEW BEST ET
NEW BEST ET
Interesting, shouldn't they measure 4'' ?
They are domed right?
NEW BEST ET
NEW BEST ET
Yes they are a dome piston. Not sure how to upload a photo here.
My mistake, I was measuring above the ring lands. Down below the ring lands 90* from the pin they measure approx. 3.990
Stock bore 302" would be 4.000" 283'" crankshaft (3.000" stroke) is used to come up with 302 cu. in.
Back in the day, we used to bore 283" block to 4.000" and we referred to that combination as a 301" Chev. Early 283 blocks (up to about 1965 or so) would usually bore to 4.000" with no problems.
Bill
SAE Member (30 years)
- Dave Koehler
The suggestion that hyperutectic pistons would be fine is just flat out foolish.
I see guys break those things on NA apps due to poor ring gap and tuning choices.
A blower of any kind just magnifies that issue.
Brazil,
Other than that ...is this
gas or alky?
injected or carbed?
roots or centrifugal?
street or strip?
Brazil,
gas or alky?
injected or carbed?
street or strip?
- Dave Koehler
The ring land area might measure that but yeah for a 4" bore you would expect the skirt area to measure around 3.995, give or take.BrazilianZ28Camaro wrote: ↑Mon Dec 16, 2019 9:16 amInteresting, shouldn't they measure 4'' ?
Something else, I thought the 2209s were a dome piston. Yes, no, maybe.
