Heavy Metal Installation
Dave Koehler
Post by Dave Koehler » Fri Jan 10, 2020 2:06 pm
It's been a eternity since I found myself having to install Heavy metal in a cast crank.
Got one now.
It's a scat cast BBC.
Just wondering how much press fit anyone has done?
I am skittish of more than .001.
Your thoughts.
k-star
Re: Heavy Metal Installation
Post by k-star » Fri Jan 10, 2020 2:53 pm
Are you installing it radially? or through the counter weight? When I install radially I like .0015 to .0020 press.
If I go though the counterweight I am ok at .0010. but I always weld mine also.
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
Dave Koehler
Post by Dave Koehler » Fri Jan 10, 2020 2:56 pm
Horizontal. CAST crank
jake197000
Post by jake197000 » Fri Jan 10, 2020 8:30 pm
I clamp it in the vice length wise,dimple it up with a punch and red locative them in.
Scotty
Post by Scotty » Fri Jan 10, 2020 8:49 pm
I would use .001" to .0015" max depending on how close tou are to the edge of the counterweight and how smoothe the internal finish is. I also loctite insitu.
GARY C
Post by GARY C » Fri Jan 10, 2020 8:53 pm
Dave I always figured you for Classic Rock... :)
Dave Koehler
Post by Dave Koehler » Sat Jan 11, 2020 8:24 am
I missed the joke but yeah.
SupStk
Post by SupStk » Sat Jan 11, 2020 11:21 am
My reamer is one inch but cuts slightly over. Since the slugs measure 1.002, it works out to be around .0015 interference. They press in tight so don't drill close to the edge of counterweight to avoid cracking.
Monty Frerichs
B&M Machine
Dave Koehler
Post by Dave Koehler » Sat Jan 11, 2020 11:32 am
The reamer thing has always been a little hit and miss for me.
I got to the point somewhere along the line that I drill and then final bore it to size.
SupStk
Post by SupStk » Sat Jan 11, 2020 8:37 pm
I've had issues with reamers cutting perfectly round holes on nitrated steel cranks but not so much with cast. If you are skeptical at .001 and are boring the hole, make it .0008?
Monty Frerichs
B&M Machine
