1400 hp Big Chevy combinations
Re: 1400 hp Big Chevy combinations
2x peak power or 2x average power? 2x average power is a lot easier with turbos.
Put Search Keywords Here
The hemi:
Sorry the photos are so small, I can't figure out how to make them display full size.
His car:
His car:
Thought I recognized the car.
Here's a notable quote before he sold it.
https://www.yellowbullet.com/threads/42 ... t-70953853
- mt-engines
So much non big block Chevy responses. Here's my response. Spend your 6k on a dart m based shortblock.
Then another 6k on the induction. Now when you Turbo it you won't kill the guy next to you at the track or be the asshole that oils it down for the rest of the day.
You must be a mind reader...englertracing wrote: ↑Fri Jan 17, 2020 1:29 pm Wonder if a big block ford has a better chance of holding up
After so many negative responses about trying to hit the number with a big block chevy, I was actually starting to look at 521-557 ford based engines.. seems strange that the Ford version would be a cheaper option, but honestly if i didn't already have the 427 truck block and steel crankshaft for $300, I think I would give it a shot with an .080 over 460 block and a 4.5 crank.
Cheap, Fast, Reliable... Choose Two.
I haven't read the replies, but there's a chance he could do it.
He would have to be really smart about finding good used parts, then spray the LIFE out of it.
It would be a bomb, and that $6k probably wouldn't last very long.
That will need A LOT of work to get you there....even supercharged/turbocharged......Here's mine for reference:
Mark Goulette
Authorized Amsoil Retailer
I knowthe intake on the right with plenum, my buddy had one on his 454 ss truck
Whats the one on the left? How big are the ports on it?
Either of those should work fine imo
Forgot to mention....those numbers on mine are WITHOUT nitrous....
Mark Goulette
- mt-engines
What's the altitude? That's like a 400hp correction for the amount of fuel you used.Coloradoracer wrote: ↑Sat Jan 18, 2020 8:53 am
-S eagle rods?
What does -S on eagle rods mean?
Thanks
Craig
Thanks
Craig
