6.0 chevy 2500 trk engine oil cooler bypass
hadmtrst8
Post by hadmtrst8 »
any comments on bypassing the junk chineze made oil cooler lines ,street driven trk.thanks 2002 2500 trk in northeast
mag2555
Re: 6.0 chevy 2500 trk engine oil cooler bypass
Post by mag2555 »
Not a problem during the Winter months, and maybe not all year long depending on what it carries around for a load on average.
Racer71
Post by Racer71 »
Change the small adapter plate that bolts above the filter to one from any truck or camaro-bird that doesn’t have it if I remember correctly.
Racer71
Post by Racer71 »
This guy
CGT
Post by CGT »
12577903(Cover) 12611384(gasket) Qty. 2 11588714(Bolt)
dfarr67
Post by dfarr67 »
Get a couple hydraulic lines made up with thread in adapters to the block. Years of trouble free service vs the gm crap.
