[/quote]
Also if your going with a light weight crank it may need Heavy Metal installed which can be expensive. You need rods that have plenty of cam to rod clearance.
[/quote]
Good point. The lightweight crank is probably unnecessary in my case anyhow.
Molnar vs K1 vs compstar crank and rods
Re: Molnar vs K1 vs compstar crank and rods
Blockman, the lifters needed .3" taller link bars. In regards to the oil pan issue, the Dart blocks use a wider main cap that extends into the pan rail area. I had to abandon my 9"deep sump pan and purchase new. Many of the manufacturers would not guarantee their pan would fit. The term "stroker clearance" did not mean it would work on a Dart block. I'm sure you have a go to pan you like to use, but the OP is talking about re-using parts.
Thanks for looking out. I knew I’d have to get a new pan already for the simple fact that my dipstick is currently on the opposite side. When skimming a few different companies pans I noted that some of them state that they’re for a dart block. Also thanks for the heads up on the 415 straight from dart via competition products. Undecided whether I will go that direction, but great to know it’s an option.rfoll wrote: ↑Sat Jan 18, 2020 10:01 am Blockman, the lifters needed .3" taller link bars. In regards to the oil pan issue, the Dart blocks use a wider main cap that extends into the pan rail area. I had to abandon my 9"deep sump pan and purchase new. Many of the manufacturers would not guarantee their pan would fit. The term "stroker clearance" did not mean it would work on a Dart block. I'm sure you have a go to pan you like to use, but the OP is talking about re-using parts.
BLOCKMAN wrote: ↑Sat Jan 18, 2020 3:36 pmMy splayed caps I put on are 7.500 wide which is wider then the Dart blocks caps and never have bothered anyone I have sold a block to...................Mikej26 wrote: ↑Sat Jan 18, 2020 11:42 amThanks for looking out. I knew I’d have to get a new pan already for the simple fact that my dipstick is currently on the opposite side. When skimming a few different companies pans I noted that some of them state that they’re for a dart block. Also thanks for the heads up on the 415 straight from dart via competition products. Undecided whether I will go that direction, but great to know it’s an option.rfoll wrote: ↑Sat Jan 18, 2020 10:01 am Blockman, the lifters needed .3" taller link bars. In regards to the oil pan issue, the Dart blocks use a wider main cap that extends into the pan rail area. I had to abandon my 9"deep sump pan and purchase new. Many of the manufacturers would not guarantee their pan would fit. The term "stroker clearance" did not mean it would work on a Dart block. I'm sure you have a go to pan you like to use, but the OP is talking about re-using parts.
Blockman, when I get a minute in a bit here to sit down and write something out I will be PM’ing you
