8k, no load, no problem. sounds strong.
will keep this updated after I haul the mail in sand.
14k rpm 0 deck
Re: 14k rpm 0 deck
You know, with a temporary auxiliary muffler or maybe just a pillow held over the exhaust outlet, you might be able to slowly run it up in neutral and hear any early sounds of contact.
Re: 14k rpm 0 deck
according to a compression ratio calculator i'm using, I am now at 15:8:1 compression ratio up from 13:2:1.
did not realize ripping .030" off the base of the cylinder would result in such a bump
Re: 14k rpm 0 deck
I am updating this as I said I would.
the engine was put under sustained heavy load this weekend running deep snow and elevation all the way on up to 14K rpm for like 20 seconds at a time, repeatedly, over and over and over again.
Increased blowby is being noted, but the engine is using 0 oil, and I have never come close to loading it as hard as I did this weekend.
also, max cylinder head temperature noted running it at ambient 10-25*F was 150*F
In the summer cylinder head temps get up around 200*F, so there is still room for things to change.
the engine revs HARD and performs well at this point.
I have to wear earplugs under my helmet as the sustained high RPM begins rattling brain cells quickly.
