V-8 Ranger
TEROL
V-8 Ranger
Post by TEROL »
Does anyone with real world experience know of a long tube header that will fit with minimal/no modification a 302/Ranger conversion ? The other possibility is a set of 289 HI-PO manifolds? Any suggestions would be much appreciated.
Protech Racing
Re: V-8 Ranger
Post by Protech Racing »
https://scontent-mia3-1.xx.fbcdn.net/v/ ... e=5ED54EE7
I moved the engine over about 1 in to clear the steering column. After I moved the body back 12in, the 91 Vette engine about 14in, Zed the frame etc.
https://scontent-mia3-1.xx.fbcdn.net/v/ ... e=5EA650E8
cv67
Re: V-8 Ranger
Post by cv67 »
Anything aftermarket that fits a mountaineer or explorer? Id hope one of those would fit.
n2omike
Re: V-8 Ranger
Post by n2omike »
There's a model year cutoff with Rangers... where some kits fit the early trucks, but not the later ones.
You need to know the year of your truck, the cutoff... and then you can do your research.
You're way ahead if you can get rid of the stock twin-I beam suspension and steering box. Putting a modern front end under it and installing a rack/pinion steering lightens things up a bunch, and also opens up some room.
TEROL
Re: V-8 Ranger
Post by TEROL »
I have a short wheelbase standard cab 2003. Also have Ranger Rikz mount kit. 1997 Explorer 5.0 W/GT40 heads, C4 trans and 4.11 8.8 rear.
Truckedup
Re: V-8 Ranger
Post by Truckedup »
The 4.0 SOHC V-6 in the newer Rangers is is kinda bulky but likley shorter than a 302? The V-6 is tight up against an A/C /heater box if your truck has it...The 95 and UP front suspension is not bad at all
Caprimaniac
Re: V-8 Ranger
Post by Caprimaniac »
Did you check out explorer forums or maybe https://www.therangerstation.com/?
Used to frequent there when my Explorer was still around, and found what i was looking for.
