Oh no, not even a little
One thing they may tend to do, however, is forget about the thousand hours of development work on a bench they put into the port years ago that's allowed them to now go by sight and measurements.
In either of the quotes given, he doesn't say he doesn't use a flow bench.
I see it in forums fairly regularly where someone says something like, “I have this cam I want to use......”, and they’re contemplating some new build.I've never heard of someone porting the head to match the cam.
So, what you're saying is, you didn't need a flow bench, for classes where porting wasn't allowed.PRH wrote: ↑Mon Jan 27, 2020 10:53 am The first engine building/machine shop I worked at(1990) didn’t have a flow bench.
There were only a few within reasonable driving distance at that time.
The only porting we did in house was very minor bowl work.
We had a guy who did any real porting, and he had a flow bench(SF-600).
At the time we were building a lot of oval track motors for a variety of different tracks and classes.
No crate motor classes existed here at that time.
All but one of the classes we built motors for had “no porting” head rules.
Occasionally we’d have the head porting guy flow an unported head for us..... but that would have been pretty rare.
We had no trouble coming up with cams for all those different classes...... and what the heads flowed wasn’t usually even part of the conversation.
There were a lot of race wins that came from those cams that were selected without the aid of flow data.
My experience has been that the “application” has way more influence on the cam selection than what the flow numbers would.
Agree 100%
Two classes allowed roller cams, one flat tappet class allowed bigger lifters.So, what you're saying is, you didn't need a flow bench, for classes where porting wasn't allowed.
I'm assuming these were mostly classes restricted to flat tappet cam, and stock diameter lifters. Maybe even restricted to stock rockers, or stock size springs. Maybe restricted to a 2bbl carb. Probably in the mid .500 lift range.
In the early 90's, we did some testing on a class where you had to run stock heads, no porting, and only a 3 angle valve job.
ya never thought of doing it that way...porting a head to match a camshaft??CamKing wrote: ↑Mon Jan 27, 2020 10:19 amIn either of the quotes given, he doesn't say he doesn't use a flow bench.
In one of the quotes, he's talking about people using a flow bench to try and match the head to the cam, in my 38 years in the cam business, I've never heard of someone porting the head to match the cam. That's 180 degrees, backwards.
That's what I said but I don't know what I'm talking about.
So how did you determine the best cam? That is what the OP is asking.PRH wrote: ↑Mon Jan 27, 2020 10:53 am The first engine building/machine shop I worked at(1990) didn’t have a flow bench.
My advice is usually along the lines of, “don’t build a motor around a camshaft”.
If the cam you have matches the ci and rpm requirements and you have the head needed how would it be any different then any other starting point where you would design the engine prior to purchasing parts?raynorshine wrote: ↑Mon Jan 27, 2020 6:15 pmya never thought of doing it that way...porting a head to match a camshaft??CamKing wrote: ↑Mon Jan 27, 2020 10:19 amIn either of the quotes given, he doesn't say he doesn't use a flow bench.
-is that reverse engineering?
I don’t think someone is going to come up with the “best” cam in one try, unless they’re duplicating an already well sorted out combo.So how did you determine the best cam? That is what the OP is asking.
