All choices listed sound good to me
Oil change intervals based on miles are not telling the whole story, equally important is the number of HOURS.
Avoid idling when possible, because the emissions system on these newer modles makes life hard on the engine, washing down your cylinders to keep the soot filter HOT.
Best oil for 6.7 Cummins
Re: Best oil for 6.7 Cummins
Nope...Delvac dino oil. The key was 3% idle time...
Wow. Thanks Graig. Interesting
I have been using delvac MX or Cat DEO in my light common rail engines. But I change it at 8000km. I hate black oil. Lol and it’s cheap
Does your EGR valve work as per factory or has it mysteriously been blocked up with a "blank gasket" ?
Craig.
No I was told that will throw fault codes. It’s an Isuzu Dmaxcjperformance wrote: ↑Mon Feb 03, 2020 1:08 amDoes your EGR valve work as per factory or has it mysteriously been blocked up with a "blank gasket" ?
I had ecu re mapped they told me it will reduce EGR activity but NOT eliminate it. I’m all ears if you know ways around it
Ah , not on DMax, i dont know an easy EGR delete on them. Great vehicle though, I'll take a dmax over any of the other similar vehicles no problem.MELWAY wrote: ↑Mon Feb 03, 2020 3:00 amNo I was told that will throw fault codes. It’s an Isuzu Dmaxcjperformance wrote: ↑Mon Feb 03, 2020 1:08 amDoes your EGR valve work as per factory or has it mysteriously been blocked up with a "blank gasket" ?
Even a reduction in egr is great.
Do you know what tune was used in yours?
Craig.
cjperformance wrote: ↑Mon Feb 03, 2020 5:43 amAh , not on DMax, i dont know an easy EGR delete on them. Great vehicle though, I'll take a dmax over any of the other similar vehicles no problem.MELWAY wrote: ↑Mon Feb 03, 2020 3:00 amNo I was told that will throw fault codes. It’s an Isuzu Dmaxcjperformance wrote: ↑Mon Feb 03, 2020 1:08 am
It’s a roo systems towing and touring tune. It made 34rwkw. More
It changed to Ute from being a slug that I hated to something decent. I have raced stock rangers and stay on their door past 100mph. And it’s amazing on fuel
