SBC Connecting Rod Offset - Honda Rod Bearing Width
- Vintagewrench
We need to know the amount of offset that SBC connecting rods have, and the width of an un-chamfered Clevite 1.889 Honda racing rod bearing. Have looked everywhere but both are hard to find.
Thanks in advance for any help you can offer.
The Old Motor
Prewar Racing Engine Rebuilding - Reproduction Engine Blocks, Heads, Crankcases - Custom-Made Bearings - Babbitting - Blind-Hole Cylinder Boring - Line boring - Connecting Rod Boring - theoldmotor.com/?page_id=29926
Re: SBC Connecting Rod Offset - Honda Rod Bearing Width
I am pretty sure I am looking at the right one. CB1665HD .896 wide the narrowed version is .851 I might have time to check the offset on a rod later on.Vintagewrench wrote: ↑Wed Feb 05, 2020 12:58 pm We need to know the amount of offset that SBC connecting rods have, and the width of an un-chamfered Clevite 1.889 Honda racing rod bearing. Have looked everywhere but both are hard to find.
Doesn’t the Mahle clevite bearing catalog pdf list the lengths of all their bearings?
Put Search Keywords Here
- Vintagewrench
Bill,Thanks for taking the time to help, CB1665HD sounds like the right bearing part #.BillK wrote: ↑Wed Feb 05, 2020 1:41 pmI am pretty sure I am looking at the right one. CB1665HD .896 wide the narrowed version is .851 I might have time to check the offset on a rod later on.Vintagewrench wrote: ↑Wed Feb 05, 2020 12:58 pm We need to know the amount of offset that SBC connecting rods have, and the width of an un-chamfered Clevite 1.889 Honda racing rod bearing. Have looked everywhere but both are hard to find.
The Old Motor
- Vintagewrench
Thanks for the lead, it did check that PDF but maybe I missed that measurement.
The Old Motor
https://www.mahle-aftermarket.com/media ... -40-16.pdfVintagewrench wrote: ↑Wed Feb 05, 2020 2:02 pm
Unless I misunderstood the original question, the answer is in the last column labeled "max length". For example, take a look at page 38.
Correct Might be confusing if you dont do it all day long.
- Vintagewrench
Thanks again! My brain short circuited the last time I looked at the catalog and I see it clearly now.ptuomov wrote: ↑Wed Feb 05, 2020 2:18 pmhttps://www.mahle-aftermarket.com/media ... -40-16.pdfVintagewrench wrote: ↑Wed Feb 05, 2020 2:02 pm
The Old Motor
The offset on SBC is .063 but, that isn't from the CL of the rod. It's the amount that the "thick" side of the rod is wider than the narrow side.
In other words, if you take .063 off the thick side, the rod will be symmetrical about it's center line.
I modify SBC, 400 rods, to use in 302 Fords.
https://www.mehanika.ru/upload/iblock/9 ... 0111dc.pdfVintagewrench wrote: ↑Wed Feb 05, 2020 2:34 pmThanks again! My brain short circuited the last time I looked at the catalog and I see it clearly now.ptuomov wrote: ↑Wed Feb 05, 2020 2:18 pmhttps://www.mahle-aftermarket.com/media ... -40-16.pdfVintagewrench wrote: ↑Wed Feb 05, 2020 2:02 pm
The problem appears to be inconsistent terminology by bearing manufacturers. In some cases it is referred to as width and others length. In roller bearing dimensions the practices seem more consistent.
Personally I think CB1663H is the more common HRJ bearing and it's width is listed as
.792 and is unchamfered.
Tom
Tom
- Vintagewrench
Thanks for the information!frnkeore wrote: ↑Wed Feb 05, 2020 5:34 pm The offset on SBC is .063 but, that isn't from the CL of the rod. It's the amount that the "thick" side of the rod is wider than the narrow side.
The Old Motor
Yesleahymtsps wrote: ↑Thu Feb 06, 2020 6:36 am Personally I think CB1663H is the more common HRJ bearing and it's width is listed as
Tom
