SBC Connecting Rod Offset - Honda Rod Bearing Width
Vintagewrench
Post by Vintagewrench » Wed Feb 05, 2020 12:58 pm
We need to know the amount of offset that SBC connecting rods have, and the width of an un-chamfered Clevite 1.889 Honda racing rod bearing. Have looked everywhere but both are hard to find.
Thanks in advance for any help you can offer.
The Old Motor
Prewar Racing Engine Rebuilding - Reproduction Engine Blocks, Heads, Crankcases - Custom-Made Bearings - Babbitting - Blind-Hole Cylinder Boring - Line boring - Connecting Rod Boring - theoldmotor.com/?page_id=29926
BillK
Re: SBC Connecting Rod Offset - Honda Rod Bearing Width
Post by BillK » Wed Feb 05, 2020 1:41 pm
I am pretty sure I am looking at the right one. CB1665HD .896 wide the narrowed version is .851 I might have time to check the offset on a rod later on.
ptuomov
Post by ptuomov » Wed Feb 05, 2020 1:48 pm
Doesn’t the Mahle clevite bearing catalog pdf list the lengths of all their bearings?
Vintagewrench
Post by Vintagewrench » Wed Feb 05, 2020 2:00 pm
Bill,Thanks for taking the time to help, CB1665HD sounds like the right bearing part #.
The Old Motor
Vintagewrench
Post by Vintagewrench » Wed Feb 05, 2020 2:02 pm
Thanks for the lead, it did check that PDF but maybe I missed that measurement.
The Old Motor
ptuomov
Post by ptuomov » Wed Feb 05, 2020 2:18 pm
https://www.mahle-aftermarket.com/media ... -40-16.pdf
Unless I misunderstood the original question, the answer is in the last column labeled "max length". For example, take a look at page 38.
BillK
Post by BillK » Wed Feb 05, 2020 2:21 pm
Correct :) Might be confusing if you dont do it all day long.
Vintagewrench
Post by Vintagewrench » Wed Feb 05, 2020 2:34 pm
Thanks again! My brain short circuited the last time I looked at the catalog and I see it clearly now.
The Old Motor
frnkeore
Post by frnkeore » Wed Feb 05, 2020 5:34 pm
The offset on SBC is .063 but, that isn't from the CL of the rod. It's the amount that the "thick" side of the rod is wider than the narrow side.
In other words, if you take .063 off the thick side, the rod will be symmetrical about it's center line.
I modify SBC, 400 rods, to use in 302 Fords.
Kevin Johnson
Post by Kevin Johnson » Wed Feb 05, 2020 10:04 pm
https://www.mehanika.ru/upload/iblock/9 ... 0111dc.pdf
The problem appears to be inconsistent terminology by bearing manufacturers. In some cases it is referred to as width and others length. In roller bearing dimensions the practices seem more consistent.
leahymtsps
Post by leahymtsps » Thu Feb 06, 2020 6:36 am
Personally I think CB1663H is the more common HRJ bearing and it's width is listed as
.792 and is unchamfered.
Tom
Vintagewrench
Post by Vintagewrench » Thu Feb 06, 2020 12:20 pm
Thanks for the information!
The Old Motor
LSP
Post by LSP » Sun Feb 09, 2020 2:47 pm
Tom
Yes
