Don't know where to put this?
Post by pdq67 »
Where is the VIN at on the complete drivetrain cradle for a 2004 Buick La Sabre car.
I suppose GM would have stamped it on both the engine as well as the transaxle..
Right, but where?
I know my '67 Camaro had it on the little pad on the block as well as at several other places on my car.
dannobee
Re: Don't know where to put this?
Post by dannobee »
Engine:
Primary location is near the oil pan rail, next to the starter.
Secondary location is below the water pump, near the A/C compressor.
Transmission:
Goodwrench Tag Location: Metal tag riveted to the transmission case, near the RH output shaft housing.
VIN derivative stamping location: Near the oil pan rail, below the metal tag mentioned above.
Secondary VIN location: Near the bellhousing area, LH side, near the engine to transmission mounting bolts.
Post by pdq67 »
Thanks dannobee.
Now to crawl under it..
