Crank scraper maybe little too tight?
ptuomov
Post by ptuomov » Sun Feb 09, 2020 8:18 pm
The windage trays maybe a little tight in this engine?
Kevin Johnson
Re: Crank scraper maybe little too tight?
Post by Kevin Johnson » Sun Feb 09, 2020 8:25 pm
Trim back the drawer handles a little. Should be fine.
af2
Post by af2 » Sun Feb 09, 2020 8:26 pm
Self clearance?
GURU is only a name.
Dave Koehler
Post by Dave Koehler » Sun Feb 09, 2020 8:37 pm
Just to cover the bases did you have the rods resized lately?
ptuomov
Post by ptuomov » Sun Feb 09, 2020 8:40 pm
Yep, those were rebuilt. I don’t recall those marks after the rods were rebuilt, but that doesn’t mean anything.
Dave Koehler
Post by Dave Koehler » Sun Feb 09, 2020 8:49 pm
I think you will find all the rods have that rub mark.
Plus your scraper is cut to clear the big end of the rod is it not?
ptuomov
Post by ptuomov » Sun Feb 09, 2020 8:57 pm
Yes. The marks were a mystery to me, but if they came from resizing the rods then that’s a logical explanation. I threw out the windage tray hypothesis, even though the geometry doesn’t really make that explanation terribly likely.
ptuomov
Post by ptuomov » Sun Feb 09, 2020 8:59 pm
I think the scraper/windage tray sheets clear the big end, where the geometry is tighter.
SupStk
Post by SupStk » Mon Feb 10, 2020 1:00 pm
Self clearance?
That would be my guess too. From the marks, I'd say both end of the rods were sized.
That isn't the part of the rod that's closest to a windage tray or scraper.
Monty Frerichs
B&M Machine
ptuomov
Post by ptuomov » Mon Feb 10, 2020 1:48 pm
That’s where the marks came from, so mystery is solved. Windage tray comment was just for fun, they obviously can’t touch the rod so high up.
Dan Timberlake
Post by Dan Timberlake » Mon Feb 10, 2020 6:49 pm
As others said -
https://www.statesidetuning.co.uk/machining/rods2.JPG
Honing pin bushings is not my favorite, except for tweaking clearance after rod straightness is measured and confirmed satisfactory.
