Piston ring question Napier second ring
hoodeng
Re: Piston ring question Napier second ring
Post by hoodeng » Tue Feb 11, 2020 5:14 pm
Is that top coating compatible with drilling?
Cheers.
LSP
Post by LSP » Tue Feb 11, 2020 5:42 pm
Ohio Rob wrote:
Tue Feb 11, 2020 4:38 pm
Here are a couple pics of the pistons.
Gas porting has been suggested, but I have a 1/16” top ring. Thoughts?
CRG0690-5 and gas port the top ring - What I meant was to put the gas ports in the upper surface of the top ring itself, Total Seal can do that to any ring. Gas ports are of benefit to 1/16" top rings too, and the gas ports in the ring itself will also get some radial tension/friction out of that big 1/16" ring as well.
Ohio Rob
Post by Ohio Rob » Tue Feb 11, 2020 6:12 pm
Thank you LSP!
I wasn’t aware that gas port slots on the rings existed.
Great info. I’m going to call total seal in the morning.
Post by MadBill » Thu Feb 13, 2020 10:20 pm
While you're at it, discuss spacers to allow narrower rings.
RCJ
Post by RCJ » Fri Feb 14, 2020 10:45 am
How long does the napier ''Hook' actually last? I was dissembling an engine last night that I had no history with.I randomly put the top and second rings back in the bore to check end gap.The top ring was a little loose , as would be expected from wear.The second ring had over .100 gap.I can see the cast 2nd ring wearing more than steel upper ring ,but this is really the first time I checked gap on disassembly.Any thoughts ?
BlitzA64
Post by BlitzA64 » Fri Feb 14, 2020 10:56 am
My buddy freshened up a 360 Sprint engine last year he had built, 1/16 rings. Changed over to the new Total Seal conform rings and it picked up. Talk to them about that package, seems to help.
engineguyBill
Post by engineguyBill » Fri Feb 14, 2020 11:56 am
There are two styles of Napier second rings. The original design was a square cut groove at the bottom of a flat-face ring, then the original design was improved to include a tapered face on the ring which resulted in a more prominent "point" and much better scraping properties. Modern Napier design is based on a "hook" design wherein the inside radius of the groove machined into the ring is curved, which results in a much sharper point and better oil scraping. The Napier second ring is typically manufactured from grey iron material, although some ring manufacturers offer these rings made from ductile iron and steel. The second ring is not exposed to high temperatures and typically is bathed in oil, therefore wear is not usually an issue with these rings and grey iron holds up very well.
I don't think your .100" gap on the second ring is caused by wear, more likely the rings were installed with that much gap.
Bill
SAE Member (29+ years)
"Do what you can, with what you have, where you are."
- Theodore Roosevelt
Post by MadBill » Fri Feb 14, 2020 7:20 pm
Because a modern Napier ring face is tapered, wear can best be judged by noting how wide the shiny contact zone is.
jed
Post by jed » Fri Feb 14, 2020 10:18 pm
Good call bill
