Page 2 of 2
Re: Piston ring question Napier second ring
Posted: Tue Feb 11, 2020 5:14 pm
by hoodeng
Is that top coating compatible with drilling?
Cheers.
Posted: Tue Feb 11, 2020 5:42 pm
by LSP
Ohio Rob wrote: ↑Tue Feb 11, 2020 4:38 pm
Here are a couple pics of the pistons.
Gas porting has been suggested, but I have a 1/16” top ring. Thoughts?
CRG0690-5 and gas port the top ring - What I meant was to put the gas ports in the upper surface of the top ring itself, Total Seal can do that to any ring. Gas ports are of benefit to 1/16" top rings too, and the gas ports in the ring itself will also get some radial tension/friction out of that big 1/16" ring as well.
Posted: Tue Feb 11, 2020 6:12 pm
by Ohio Rob
Thank you LSP!
I wasn’t aware that gas port slots on the rings existed.
Great info. I’m going to call total seal in the morning.
Posted: Thu Feb 13, 2020 10:20 pm
by MadBill
While you're at it, discuss spacers to allow narrower rings.
Posted: Fri Feb 14, 2020 10:45 am
by RCJ
How long does the napier ''Hook' actually last? I was dissembling an engine last night that I had no history with.I randomly put the top and second rings back in the bore to check end gap.The top ring was a little loose , as would be expected from wear.The second ring had over .100 gap.I can see the cast 2nd ring wearing more than steel upper ring ,but this is really the first time I checked gap on disassembly.Any thoughts ?
Posted: Fri Feb 14, 2020 10:56 am
by BlitzA64
My buddy freshened up a 360 Sprint engine last year he had built, 1/16 rings. Changed over to the new Total Seal conform rings and it picked up. Talk to them about that package, seems to help.
Posted: Fri Feb 14, 2020 11:56 am
by engineguyBill
RCJ wrote: ↑Fri Feb 14, 2020 10:45 am
There are two styles of Napier second rings. The original design was a square cut groove at the bottom of a flat-face ring, then the original design was improved to include a tapered face on the ring which resulted in a more prominent "point" and much better scraping properties. Modern Napier design is based on a "hook" design wherein the inside radius of the groove machined into the ring is curved, which results in a much sharper point and better oil scraping. The Napier second ring is typically manufactured from grey iron material, although some ring manufacturers offer these rings made from ductile iron and steel. The second ring is not exposed to high temperatures and typically is bathed in oil, therefore wear is not usually an issue with these rings and grey iron holds up very well.
I don't think your .100" gap on the second ring is caused by wear, more likely the rings were installed with that much gap.
Posted: Fri Feb 14, 2020 7:20 pm
by MadBill
Because a modern Napier ring face is tapered, wear can best be judged by noting how wide the shiny contact zone is.
Posted: Fri Feb 14, 2020 10:18 pm
by jed
Good call bill
Posted: Thu Apr 08, 2021 10:17 pm
by swampbuggy
The price of Wisdom is Age...right Bill ?
Mark H.
Posted: Thu Apr 08, 2021 11:43 pm
by MadBill
All too true. I need to type faster while I'm still extant, to disseminate as much as I can of all I've learned (and not yet forgotten) in 77 years...
Posted: Fri Apr 09, 2021 3:15 am
by Mark O'Neal
I'd get a different set of pistons.
Posted: Fri Apr 09, 2021 3:16 am
by Mark O'Neal
MadBill wrote: ↑Thu Apr 08, 2021 11:43 pm
So....my name....so far.
