Fixing a cam?
econo racer
Fixing a cam?
Post by econo racer »
I have a BBC solid roller with one damaged lobe. Not real bad but ground down some. How much does it cost to repair this? Or is it better to buy a new one?
rebelyell
Re: Fixing a cam?
Post by rebelyell »
JMO: If your BBC solid roller cam is an off-the-shelf piece, it could be cheaper to buy a new one.
Suggest you ask one of the many re-grinders for advice: CamCraftCams, Crower, Egge, OregonCamshaft etc
Re: Fixing a cam?
Post by pdq67 »
rebelyell wrote: Mon Feb 10, 2020 10:42 am JMO: If your BBC solid roller cam is an off-the-shelf piece, it could be cheaper to buy a new one.
May I add, "Delta", out in the NW if they are still around?
1972ho
Re: Fixing a cam?
Post by 1972ho »
I had a flat tappet solid cam welded and reground and still have it running it was welded by webcam in Riverside Ca and sent back to bullet to be ground it was 75.00 for the welding and 75.00 for the grind.
Krooser
Re: Fixing a cam?
Post by Krooser »
Mike Jones can fix it...
CamKing
Re: Fixing a cam?
Post by CamKing »
Krooser wrote: Tue Feb 11, 2020 1:55 pm Mike Jones can fix it...
It would depend on how bad it's damaged.
The other issue would be, having a lobe profile close to what's on it.
It's always best, to contact the company that made the cam, since they'll have the exact profiles to grind back on it.
jeff swisher
Re: Fixing a cam?
Post by jeff swisher »
Or the guy grinding it could cut a master off of a lobe that was good.
mt-engines
Re: Fixing a cam?
Post by mt-engines »
jeff swisher wrote: Tue Feb 11, 2020 8:13 pm Or the guy grinding it could cut a master off of a lobe that was good.
Yeah, im sure thats more cost effective than going to the person with the original master.
jeff swisher
Re: Fixing a cam?
[/quote]
People brings cams into the local cam shop all the time with bad lobes and some of those cams have been around longer than the company that built the cam.
If you have spare masters and the cam is a pretty nice profile that you do not have you cut a master and now you do have it.
But you are right if the cam can be sent back to the guy with the master it should be more cost effective.
CamKing
Re: Fixing a cam?
Post by CamKing »
You never want to do this, unless there are no other options available.
When you grind a lobe off of a master, that lobe is a copy of the master lobe, but tolerances and wheel size variations make it less then a 100% accurate copy.
Now if a cam company makes a master off of one of the cam lobes, that master is now a copy of a copy, and the accuracy drops even more. If the lobe he measured to make the new master was worn at all, that also drops the accuracy.
Now he takes that master, and grinds the bad lobe, so now that lobe is a copy of a copy of a copy, with so many copying errors that it could cause major issues to the rest of the valvetrain.
jeff swisher
Re: Fixing a cam?
Thanks CamKing I can see all that happening now that you said it.
econo racer
Re: Fixing a cam?
It is an old Lunati.
CamKing
Re: Fixing a cam?
Post by CamKing »
econo racer wrote: Thu Feb 13, 2020 12:29 am It is an old Lunati.
Take a couple pictures of the bad lobe, and email them to me: tech@jonescams.com
steve316
Re: Fixing a cam?
Post by steve316 »
A new cam is the cheapest up grade you can do for high performance engine. With the new profiles that available you may pick up some HP with the new cam while your at it.
