Glue for extensions on heater core lines
Caprimaniac
Post by Caprimaniac »
Hello.
Upgrading my street "racer" yhis Winter; engine rebuild, brakes Upgrade and now also getting heat to the driver compartment....
Heater core has steel pipes sticking through the firewall. Previously cut down in lenght because engine is placed very far rearwards.They are steel (or brass)?
Had some 90 deg cooling hose fittings lying around. And luckily a drillbit With diameter matching the steel pipes. So, I'm pushing the 90 deg fittings onto the steel pipes from the heater core.... And it's gonna keep my feet warm and windscreen mist-free.
What you suggest for a Chemical that keep it all leak free? Epoxy? Loctite 603?
Thanks, chemxperts.
Nefario
Re: Glue for extensions on heater core lines
Post by Nefario »
Is solder a chemical? And yes, you can solder steel, especially with the lap joint you're describing. Use "real" tin/lead solder for easy wetting of the parts, not lead free.
If the core is all metal I suspect it's soldered brass which would be extremely easy to solder. If it's plastic with crimped-on ends the metal could be aluminum which would require special solder and some luck.
Dave
Walter R. Malik
Post by Walter R. Malik »
Caprimaniac wrote: Mon Feb 10, 2020 1:39 pm Hello.
Thanks, chemxperts.
I would use "extended dry time J B Weld epoxy" for that.
Caprimaniac
Nefario wrote: Mon Feb 10, 2020 2:10 pm Is solder a chemical? And yes, you can solder steel, especially with the lap joint you're describing. Use "real" tin/lead solder for easy wetting of the parts, not lead free.
Solder is a Chemical... No bout. What is not Chemicals? Things like EM Waves, gravity.... Maybe plasma?
That's an argument, if the bends had been copper, brass etc. But they're plastic. But; if I had some bends in the right diameter, it might have been a better option than the plastic (reinforced BTW) bends.
So. I will go With Malik's suggestion. As was the answer my pal gave me thr other day. Argument was there won't be a tight enough Space between the two pipes as to harden the Loctite.
Thanks for confirming, Walter.
Walter R. Malik
Caprimaniac wrote: Tue Feb 11, 2020 4:53 am
Be sure to use original "J B WELD" as substitutes do not usually share the high temperature rating.
Nefario
Post by Nefario »
Caprimaniac wrote: Mon Feb 10, 2020 1:39 pmHeater core has steel pipes sticking through the firewall. Previously cut down in lenght because engine is placed very far rearwards.They are steel (or brass)?
Caprimaniac wrote: Tue Feb 11, 2020 4:53 am.... if the bends had been copper, brass etc. But they're plastic. But; if I had some bends in the right diameter, it might have been a better option than the plastic (reinforced BTW) bends.
.....okeh..... [-X
Dave
