Current NHRA Pro-Stock Cyl. heads
swampbuggy
Post by swampbuggy »
Does anybody know pretty close as to what the flow numbers are on the current Pro-Stock heads ? Mark H.
mag2555
Re: Current NHRA Pro-Stock Cyl. heads
Post by mag2555 »
Your talking 500 cfm on the Intake and 330 out the Exh @ .900" lift pretty much.
mt-engines
Post by mt-engines »
mag2555 wrote: Tue Feb 11, 2020 7:01 am Your talking 500 cfm on the Intake and 330 out the Exh @ .900" lift pretty much.
LMFAO.... not even close to that little.
LSP
Post by LSP »
mt-engines wrote: Tue Feb 11, 2020 8:34 am
It was that little 25 years ago lol
maxracesoftware
Post by maxracesoftware »
swampbuggy wrote: Tue Feb 11, 2020 6:51 am Does anybody know pretty close as to what the flow numbers are on the current Pro-Stock heads ? Mark H.
from PipeMax v4.50 :
Code: Select all
Bore=4.75000   Stroke=3.52000   499.01057710 Cubic Inches @ 10000 RPM  Intake System= 124.66269 VE%
Complete Intake System Flow     @28in.= 600.0000 -to- 642.5146 CFM @ 1.200000 Lift (0.00000 VE% Loss)
Cylinder Head  Intake Port Flow @28in.= 600.0000 -to- 642.5146 CFM @ 1.200000 Lift (124.66269 VE%)
Cylinder Head Exhaust Port Flow @28in.= 380.0000 -to- 406.9259 CFM @ 1.100000 Lift (no Flow Pipe)
MaxRace Software
Stan Weiss
Post by Stan Weiss »
I have no idea what todayes heads flow. These are from some time ago. They were not just ported by Darin but are the heads he designed for Ford.
Ford Pro Stock RCV (Canted Valve) Ported Darin Morgan SF600 Alum
Exhaust = No Pipe
2.575
0.20000 - 175
0.30000 - 273
0.40000 - 369
0.50000 - 457
0.60000 - 530
0.70000 - 583
0.80000 - 614
0.90000 - 637
1.00000 - 644
1.865
0.20000 - 103
0.30000 - 154
0.40000 - 200
0.50000 - 243
0.60000 - 286
0.70000 - 327
0.80000 - 344
0.90000 - 351
1.00000 - 360
swampbuggy
Thanks to Larry and Stan for your input. I listened to an audio interview somebody did with Mr. Godbold at Comp. Cams which prompted me to run some math calculations. One was....appx. 1500 H.P. divided by 644 C.F.M. = 2.33 H.P. per CFM . He also mentioned a percentage of the diameter of your intake valve would equate to the needed valve lift. Examples used were appx. 40 percent for NASCAR....appx. a 2.230" x .40 = .892" lift. Pro-Stock close to 50 percent. 2.57" x .50 = 1.285" lift ?????? Mark H. BTW the NASCAR I.V. size was a guess, the 40 percent was Billy's words.
JohnsnsFord2@aol.com
Post by JohnsnsFord2@aol.com »
Stan Weiss wrote: Tue Feb 11, 2020 2:21 pm I have no idea what todayes heads flow. These are from some time ago. They were not just ported by Darin but are the heads he designed for Ford.
Exhaust = No Pipe
2.575
0.20000 - 175
0.30000 - 273
0.40000 - 369
0.50000 - 457
0.60000 - 530
0.70000 - 583
0.80000 - 614
0.90000 - 637
1.00000 - 644
1.865
0.20000 - 103
0.30000 - 154
0.40000 - 200
0.50000 - 243
0.60000 - 286
0.70000 - 327
0.80000 - 344
0.90000 - 351
1.00000 - 360
were those the heads Larry Morgan ran before he gave up on Ford....also the same style CW runs?
Darin designed 2 styles ??
Stephen Johnson #2162
Horace Johnson #2167
SS/D 427 Ford Fairlane NHRA-IHRA
Ex-Jim Van Cleve
1985 Mustang GT N/A 331
Stan Weiss
JohnsnsFord2@aol.com wrote: Wed Feb 12, 2020 1:20 am
Exhaust = No Pipe
2.575
0.20000 - 175
0.30000 - 273
0.40000 - 369
0.50000 - 457
0.60000 - 530
0.70000 - 583
0.80000 - 614
0.90000 - 637
1.00000 - 644
1.865
0.20000 - 103
0.30000 - 154
0.40000 - 200
0.50000 - 243
0.60000 - 286
0.70000 - 327
0.80000 - 344
0.90000 - 351
1.00000 - 360
From what I can remember there were 2 heads designed. Darin designed 1 of them and for some reason the other head was the one used.
SchmidtMotorWorks
Post by SchmidtMotorWorks »
Stan Weiss wrote: Thu Feb 13, 2020 11:12 am
Exhaust = No Pipe
2.575
0.20000 - 175
0.30000 - 273
0.40000 - 369
0.50000 - 457
0.60000 - 530
0.70000 - 583
0.80000 - 614
0.90000 - 637
1.00000 - 644
1.865
0.20000 - 103
0.30000 - 154
0.40000 - 200
0.50000 - 243
0.60000 - 286
0.70000 - 327
0.80000 - 344
0.90000 - 351
1.00000 - 360
The head didn't determine the flow, there was enough stock to cut about any shape you wanted into it.
It was basically a blank canvas as most heads of that class are.
The one dimension that had a little gravity is the intake valve axis to cylinder bore axis was about 9 degrees as designed.
Could have been made a couple degrees up or down from there.
Exhaust = No Pipe
2.575
0.20000 - 175
0.30000 - 273
0.40000 - 369
0.50000 - 457
0.60000 - 530
0.70000 - 583
0.80000 - 614
0.90000 - 637
1.00000 - 644
1.865
0.20000 - 103
0.30000 - 154
0.40000 - 200
0.50000 - 243
0.60000 - 286
0.70000 - 327
0.80000 - 344
0.90000 - 351
1.00000 - 360
the other head wasn't approved by nhra!?? I thought I heard that...
Ex-Jim Van Cleve
