8.2 mexican block 338ci turbo piston ring land question
fomocosteve
Post by fomocosteve » Thu Feb 13, 2020 11:50 am
Hi, I have a question, I have a set of 30cc dish pistons I can make work in a combo im wanting to turbo, can anyone tell me what their thoughts are of a .165 top ring land in a turbo application with forged pistons. I can make it an e85 dedicated build if required to make it live.... 338 cubes, 750 hp @ 6800-7000 rpm...... 8:1 compression, carrillo 1.85 rods,..... Bryant 3.25 crank......
Will it live if the rings are gapped correctly... even on E85.... Thoughts Please.....
Steve
LSP
Re: 8.2 mexican block 338ci turbo piston ring land question
Post by LSP » Thu Feb 13, 2020 12:28 pm
Steve
Find out how much cross-section is between the valve pockets and the top ring groove, that is more important in your case.
BILL-C
Post by BILL-C » Thu Feb 13, 2020 1:17 pm
Looks like you have a 4.065 bore in that 338 cid 302 mexican block. The pistons are a concern, but i would be more worried about the block at the 750 hp level. You might be wasting a real nice crank and set of rods. Check how thin piston is between inside of top ring groove and intake valve pocket . Piston might possibly be thin between id of ring groove and edge of dish also. I would call whoever made pistons and ask their opinion. I personally would be a little worried.
Carlquist Competition Engines
KnightEngines
Post by KnightEngines » Thu Feb 13, 2020 7:27 pm
That block will bust open like a rotted tomato.
Don't even think about it!
Get an SHP block, then worry about pistons.
fomocosteve
Post by fomocosteve » Thu Feb 13, 2020 8:43 pm
I just took a stab at the cubic inch, theyre actually 4.056, and i was going to half grout the block ??? Just checked it at 335.9 cubes, cant rough guess anything around here without being called on it lol...
KnightEngines
Post by KnightEngines » Thu Feb 13, 2020 8:45 pm
Grout won't help, the torque of a turbo motor will tear the mains out.
You NEED an aftermarket block.
fomocosteve
Post by fomocosteve » Thu Feb 13, 2020 8:48 pm
Ok, thanks Knight, im hearing ya, what if i used em in a 351w block i have laying around, would the ring land still be a problem?
KnightEngines
Post by KnightEngines » Thu Feb 13, 2020 9:52 pm
351w block will take it.
Ring lands will live on e85 if the tune is good.
But you don't have much margin for error in the tune, if it pings it'll break the lands.
Probably best to get some boost specific pistons - spend more up front & it'll be cheaper in the long run.
fomocosteve
Post by fomocosteve » Thu Feb 13, 2020 11:01 pm
Okay, thanks, Just seeing if they were usable, i think ill move em on, I dont have a use for them, what would you recommend as a minimum ring land thickness for boost while im shopping for pistons?
Mark O'Neal
Post by Mark O'Neal » Fri Feb 14, 2020 12:12 am
I'd recommend a .250 minimum BUT...... If the tuneup is right, it doesn't matter how I make the pistons. If the tuneup is wrong, it doesn't matter how I make the pistons.
KnightEngines
Post by KnightEngines » Fri Feb 14, 2020 12:17 am
Another point - your crank won't go into a 351w block.
fomocosteve
Post by fomocosteve » Fri Feb 14, 2020 2:06 am
Yeah, id have to use other crank for use with the 3" main. Thanks guys
