What kind of issues would I see with a turbo with to small of a an AR on the turbine?
jet1
Post by jet1 »
Running 2 60 mm compressors at 1000 hp with ex turbin AR of .68. seems very touchy for tulipping valves. It is a 260 ci running e85 @ 15 lbs @ 7200 rpm.
Orr89rocz
Re: What kind of issues would I see with a turbo with to small of a an AR on the turbine?
Post by Orr89rocz »
Hard to say without more info.
What size motor? Rpm range? What size turbine wheel? How much boost?
Any backpressure readings?
jet1
Post by jet1 »
Ya sorry got pulled away and didn't realize that I hit post. Edited it. I do not have any back pressure measurements but will be doing that. I guess wondering what I should be seeing at the turbo flange?
Orr89rocz
Post by Orr89rocz »
Thats doing well on just 15 psi for 260 inches. But i dont think you would have issues with those turbos assuming turbine is in the high 50’s mm low 60’s mm or bigger.
I ran 60mm compressors with 65 mm turbines and .68 ar on my mild 400 sbc and only turned 5500 rpm making 800 hp crank 640 whp. 14 psi. No issues
jet1
Post by jet1 »
Thanks, that is good to know. Ya the power is decent if I could keep it together. it will be going back on the dyno in a month, so I am just trying get things to look at. timing is another thing which seems high to me at 32 deg all the way up to 22 lbs.
