spark plug reccomend....
Re: spark plug reccomend....
What application?? What other particulars on the engine?
Street Drag Oval track Marine?? How much compression??Carb??
They should use a 5/8""Hex gasketed type plug.NGK has a good selection of colder type plugs for race or extended full throttle situations such as marine use.
Its actually .708 reach tapered seat. NGK TR6 would be a decent starting point for a 10.1 comp street/strip engine...provided you can use a projected tip..which I assume you could with 10.1 on a 383.
street, 10-1 compression, holley sniper fuel injection, should make roughly 485hp
gm performance page states 3/4 reach specifically?
https://www.gmperformancemotor.com/parts/19300955.html
Hmmm...Well, now you got me researching that. That head always used to call for AC FR3LS or MR43LTS plug which is 5/8 hex .708 reach. Can't see a spark plug number recommendation by GM anymore. .750 5/8 tapered isn't common. Im gonna look through some old catalogs. Weirdrewguy wrote: ↑Thu Feb 20, 2020 3:07 pmgm performance page states 3/4 reach specifically?
Heck, as of ten years ago autolite did not make a .750 tapered plug. I know .708 is very common. I know other gm heads also used the .708 depth of that era. My money is on CGT that it is .708.
Paul
Paul
There are no .750" reach tapered seat plugs. If a head is machined for a tapered seat .708" reach then a .750" gasket plug will end up the same place in the chamber. They are interchangeable, assuming the head is machined with a countersunk lead in at the top of the threads to accommodate a tapered seat plug. If the head is not machined for a tapered seat plug then .750" gasket is the only choice.CGT wrote: ↑Thu Feb 20, 2020 3:39 pmHmmm...Well, now you got me researching that. That head always used to call for AC FR3LS or MR43LTS plug which is 5/8 hex .708 reach. Can't see a spark plug number recommendation by GM anymore. .750 5/8 tapered isn't common. Im gonna look through some old catalogs. Weirdrewguy wrote: ↑Thu Feb 20, 2020 3:07 pmgm performance page states 3/4 reach specifically?
When heads will accept I either, I prefer the tapered seat.
