Engine Masters rod ratio test results
tchapps88
Post by tchapps88 » Mon Mar 02, 2020 9:25 am
for the ones that watched it what was your take on it? Were you surprised the shorter rods made more power?
ClassAct
Re: Engine Masters rod ratio test results
Post by ClassAct » Mon Mar 02, 2020 9:37 am
Is there a YouTube link to that or something? I'd love to watch that.
Walter R. Malik
Post by Walter R. Malik » Mon Mar 02, 2020 9:48 am
No ... not at all.
Some people have simply kept their mouth shut because all the "experts" out there know everything; without actually testing.
tchapps88
Post by tchapps88 » Mon Mar 02, 2020 10:08 am
not for this one, its on motor trend on demand
Post by pdq67 » Mon Mar 02, 2020 10:15 am
I have to ask if the intake and exhaust tracks as well as the cams matched to the individual rod ratios before I believe that a short rod ratio will make more power than a long rod ratio.
Only because of less piston/cylinder side-loading for the longer rod ratio is all.
englertracing
Post by englertracing » Mon Mar 02, 2020 11:16 am
All of the 900+ hp sprint cars went from 6" to 5.9" rods as the intake tracts grew larger.... Like 2.900 or 3" butterflies.....
But its probably as much about the piston and rings as it is about the r/s
CamKing
Post by CamKing » Mon Mar 02, 2020 11:40 am
Exactly. If the camshaft wasn't optimized for each rod length, The test is meaningless.
Post by PackardV8 » Mon Mar 02, 2020 12:06 pm
Those of us there back in the day remember the 302" SBF would never make any power "because the rods are too short for a 3.00" stroke" and today with good heads, those little suckers are running a 3.40" stroke with a worse rod/stroke ratio and making enough power to split the block.
A 302" has a 3.00" stroke with a 5.090"connecting rod. The 347" increases the stroke to 3.40" and a 5.40" rod. This drops the rod ratio from 1.696:1 for the 302" to 1.588:1 for the 347".
Joe-71
Post by Joe-71 » Mon Mar 02, 2020 12:33 pm
In my experience the only time a shorter rod makes more power is when the intake port is too big for the cubic inches and they keep the same heads and intake, headers. Joe-71
Joe-JDC
blackford
Post by blackford » Mon Mar 02, 2020 12:40 pm
In 2003, I built a street driven SBF 331 using 289 rods that are 5.155". I used a KB322 383 Windsor piston. Rod Ratio works out to be slightly less than a 5.4 rod 347...1.586. I also used fully ported '70 351W heads with 1.94/1.6 valves and had some valve unshrouding done (160cc intake ports and 60cc exhaust ports). 9.8:1 compression. Single Plane intake, 750 HP, 282S Comp Cam, Dougs stepped Tri-Y headers. The engine makes 430 HP @ 6500 and is still making 400 HP @ 7000. More than just about anyone in the SBF community would have believed. Maybe i got lucky and choose components that all worked very well together.
65 Mustang FB, 331 custom built with 289 H beam rods and 383W piston, 282S cam, Ported DOOEs, T5z, 9" 3.89 gears. 430HP@6500
2013 Corvette 427 Convertible daily driver
'65 Fastback
ClassAct
Post by ClassAct » Mon Mar 02, 2020 1:03 pm
Ok, thanks.
engineguyBill
Post by engineguyBill » Mon Mar 02, 2020 1:14 pm
^^^^^^^^^^^^^^ I agree with this statement. One of the advantages of longer rods is the fact that there is more piston dwell at TDC, however the camshaft needs to be designed to take advantages of this feature, as well as other features of long rods. Camshaft design for a long rod engine will be different than the camshaft design necessary to take advantage of short rod features.
Bill
SAE Member (29+ years)
n2omike
Post by n2omike » Mon Mar 02, 2020 1:40 pm
On the show, they had basically 'too much cam and head'... The short rods made more top end, and the long rods made more low end power. But it wasn't huge either way. When they did a steady state run (engine locked to one speed) the numbers were pretty much identical.
478 inch Big block Chevy (big bore, short stroke... 4.5" bore, and less than 4" stroke) with 365cc heads and a big roller.
Tom Walker
Post by Tom Walker » Mon Mar 02, 2020 1:51 pm
Without each rod ratio engine completely optimized and tuned for that combination, I personally don't think it gives us anything except something to continue to discuss, which is fine. I do believe there is merit in using the best ratio for your particular application.
If memory serves me, I believe it was Pro Stock veteran Warren Johnson that said his rod ratio was whatever connected the piston to the crank, but he was also very cagey about what he was actually doing at times.
BlitzA64
Post by BlitzA64 » Mon Mar 02, 2020 2:10 pm
It's all combination, they both will work just like different things. In a wide open no holds barred build rod length would be way down the list for me. In a limited class rule type deal it can move substantially up the list in my opinion. Just swapping out rods and not optimizing the build is a waste of time and effort, maybe it works and maybe it doesn't.
