So true.Caprimaniac wrote: ↑Mon Mar 09, 2020 5:50 pm A person who take care to do Critical measurements and apropriate changes to machine parts to fit a combustion engine and, in the end, assemble the engine and make it more reliable, longer lasting & higher output than a layman would.
I had the great fortune to learn about engine building from the group my dad put together at Champion Spark plug's test facility in Long Beach CA. At the time, there was nothing like it. The men that worked there, were all the top in their fields. Rocky Philipp, former Indy Crew Chief, and fantastic fabricator. Art Oehrli, former Engine Builder for Jim Hall Chaparrel Race Team. Earl Parker, former Indy Crew Chief. Robert Strahlmann, former Indy Crew Chief. Art Lamey, former USAC and NASCAR Chief Mechanic, and fuel systems expert. Dick Jones, ran dyno development for Harman & Collins, turbine development for Garrett AiResearch, supercharger development for Paxton Division of McCulloch Motors, and was a top engine builder in boat and land speed racing.
This group was responsible for developing many successful engines in IndyCar, NASCAR, Formula 1, USAC, SCCA, IMSA, and other forms of racing.
When I was old enough to get to work around these people, I quickly learned their "Speed Secret" that made them so successful. Their "Secret" was, they took the time to measure everything, and make sure it was correct, and made sure everything was put together correctly. For many things they wanted to measure, there wasn't tools made to measure them, so they made their own tooling. The first lesson I learned, was from Rocky. He told me to disassemble a multi-stage oil pump, clean it, and put it back together. No problem. I spent a good amount of time, making sure it was clean, and put together correctly. When I was done, Rocky said, OK, now you can take it apart, and do it correctly. He had me measure each pump gear O.D., and each gear housing I.D., and match the gears with the correct housings, so the clearances between each gear and it's housing would be as close to the same as possible. To a 16 year old, this sounds like overkill, but it was this type of attention to detail that made them so successful.
