Salvage 400 update: 66 SS
Compression: Note: trying to get the compression up to 9.75/1 (worried about the quench being so low with the stock dish pistons I believe the are 25cc) (oh found some old compression readings 140, 145, 150, 150, 152, 150 and two I couldn't get to.)
Heads: The 49 Iron Eagles only ended up being 53cc, but we cut off 1cc so (.006) (I guess that is normal for heads to be that far off???)
Crank: - took it in to get balanced the guy said its been blown before. One of the weights took an impact and the rear thrust part (not sure if i'm saying that right) of the crank has been welded on/repaired (not perfect but you could see and it had been welded on) But has been running for 6 years.
Block: getting it decked but asked not to cut over .010 (hope I have that right) worried about the intake fitting since we took off .006 of the heads.
Rods: -Bought ARP bolts for mains, caps and heads. The machine shop talked me into re-sizing the Rods since I put ARP studs in . (80 bucks) Says it distorts them when pressed in. (not sure of that, used a press and a aluminum block with hole in it. )
Cam: went with COMP Cams SK12-246-3 Xtreme Energy 230/236
Old Cam says on the end 114822 11-45 01 (on back of the cam I found a 0288 D1) If anyone can figure out what this cam is I'd appreciate it!
Note: found a howards cam with that number but there is no way it had that lift. (new cam has about .010 more lift at 0.487"/0.490")
Wait time: during wait time, removed dash/steering wheel and painting both and should be dry by tomorrow. Thinking about dancing again to make money for new dash pad, SS guages and new turn signal switch!
lolol
Original post:
Just FYI, I haven't built an engine since 84 (383) so take it easy on me!
So I have 66SS with 406 with 700r4 and 411s & 750 holley, 1.6 roller rockers (many owners)
So not knowing anything about the motor other than it ran ok but missing power I removed the double hump heads (54cc) to find out it has dish pistons 40cc (did the plexiglass across the top and a syringe to both). So my question is if I throw a set of Dart iron eagle 49cc 215s on it and get it to 9.5/1 will it still run decent? Just not sure about those pistons? (no money to replace them!)
