I believe I have a '62 Healey BJ7, block casting number AEC881.
I need the big end specification for the connecting rods, casting number AEC790S
Thanks,
Healey Rod Specification AEC790S
Re: Healey Rod Specification AEC790S
From the AERA Prosis software:
2.1140-2.1145" (53.696-53.708 MM)
You really need to join AERA.
Re-use the original rod bolts and nuts if at all possible. Replacements from the usual suspects are real crap, completely un-useable.
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
The original bolts are crap too, with a small diagonal pin in their head that usually breaks off.
The bolt's round head has a flat that can be used to hold it when tightening, with a shim or small screwdriver wedged between it & the rod. At least it wasn't Whitworth.
Good luck.
Good luck.
The replacements my customer brought to me for his 3000 were a full .010" small on shank diameter and that pin was the wrong angle and length, the bolt heads came no where near seating. I think I have pics, I'll look tomorrow.
QC was lacking on this batch of offshore hardware.
