Page 2 of 2
Re: I am 84 YO., and building my last SBC 400 and will be over
Posted: Thu Mar 19, 2020 6:00 pm
by oldhead
ClassicComp wrote: ↑Thu Mar 19, 2020 1:23 pm
I think this is the guy that has a Holley dp on his car and the secondary’s are controlled by a cruise control unit on something.
He was supposed to post pics, Yes the cruise control is very good, takes a little over one second to open the secondary after the primary is open full Bob Oldhead
Posted: Thu Mar 19, 2020 7:47 pm
by ClassicComp
Interesting idea, please post some pics
Posted: Thu Mar 19, 2020 8:44 pm
by Kevin Johnson
Posted: Fri Mar 20, 2020 3:05 am
by enigma57
An interesting idea indeed! Would appreciate any pics or further info. We will be running an annular booster 600 CFM Autolite carb original to a '58 Mercury Marauder 383 engine on son's 350 Chevy (road car). It would be fun to experiment with a similar mechanism for opening the secondaries on our carb.
Best regards,
Harry
Posted: Fri Mar 20, 2020 8:53 am
by rebelrouser
Years ago, racing in the no box class, I set up a throttle controller using an air cylinder similar to the link. I had two line locks one for front and one for the back brakes. I had a small air tank in the car and I kept it pressurized with a sears 12 volt tire compressor between rounds. I had it set that when I energized the line locks, the air was exhausted from the cylinder and the throttle would only open to my preset line launch rpm. When I released the button the line locks released and the air cylinder opened the throttle. The other benefit was I could adjust the speed of the throttle opening with a orifice in the line from the air bottle, so on slick tracks it would help keep the tires from spinning. Also the drivetrain was under load so the shock of a transbrake was eliminated as well. It really worked great, won a lot of races. A similar system off a throttle switch could easily operate the secondaries. Racing NSS now, no longer legal to run.
https://www.jegs.com/p/K-R/K-R-Performa ... 6/10002/-1
Posted: Sat Mar 21, 2020 12:40 pm
by oldhead
SORRY NO PICTURES,I don't know how Oldhead
Posted: Sat Mar 21, 2020 2:34 pm
by Caprimaniac
Cool, Oldhead!
Click "Attachments" under the bottom of the white screen- area where you add text. Add Your files (Pictures) from yur PC.
Very mucho good Luck With you "last" build.
Posted: Sat Mar 21, 2020 8:52 pm
by Elroy
Fantastic to be thinking and doing it at 84 years. Much less that much horsepower. I hope I can be in a similar situation, not too far behind you in seniority
Posted: Sun Mar 22, 2020 6:50 am
by econo racer
What track will you try it at. Love to see it
Posted: Thu Mar 26, 2020 4:29 am
by dwilliams
I've listened to all the exposition about bearing speed, oil heating, frictional losses, yadda yadda, but I've also taken apart a lot of 400 cores and never noticed any unusual main bearing issues, and I freshened up many 400 and 375 dirt track motors back when useable factory blocks were still a thing. Other than the usual distress from poor tuning and refusal to run air filters I never noticed anything unusual there, either.
I can accept that things might be much different for an engine running a 500 mile NASCAR race, but unless you're planning to do that, one is as good as the other.
