Pete Jackson BB Chevy noise gear drive parts missing
Ron Miller
Post by Ron Miller »
I have an older Pete Jackson BB Chevy noise gear drive part # 0782-327-ICN that is missing a few pieces. The offset bushings, cam thrust bearing, and the bronze or roller thrust bearing. Will the offset cam bushing from an MR Gasket kit work? How about the cam thrust bearing, is this the common bearing used on just about every roller set? And last what about the front thrust bearing?
Thanks for looking, =D>
Ron Miller
ClassAct
Re: Pete Jackson BB Chevy noise gear drive parts missing
Post by ClassAct »
I know the Mr. Gasket bushings work.
About the thrust bearing...I would take the gear and such down to the local bearing house and let them find something that will work.
That's all I got.
Alaskaracer
Post by Alaskaracer »
I'd toss it and either get a quality chain or if you're set on a gear drive, a full cover style like one from Milodon. Pete Jackson drives are junk.
Mark Goulette
Authorized Amsoil Retailer
GARY C
Post by GARY C »
Ran one in my SBC, the harmonics separated the front main web from the block... I was warned but didn't listen.
CGT
Post by CGT »
The Michael Jackson gear drives have better harmonics but are no longer available :roll:
GARY C
Post by GARY C »
CGT wrote: Mon Mar 23, 2020 9:11 pm The Michael Jackson gear drives have better harmonics but are no longer available :roll:
There bad there bad you know it....
Ron Miller
Guys,
Thanks for the Humor and replies. :lol: :lol: :lol:
Ron Miller
GARY C
Post by GARY C »
Ron Miller wrote: Mon Mar 23, 2020 9:45 pm Guys,
I still have the one I ran, now I use it for mocking up a cam for the degree wheel, the crank gear is not press fit and the cam gear is drilled for degree bushings, so I can get a baseline cam install in-case I need to advance or retard crank gear before installing the actual crank gear.
Geoff2
Post by Geoff2 »
The missing parts might be a sign....
