Page 1 of 1
Pete Jackson BB Chevy noise gear drive parts missing
Posted: Mon Mar 23, 2020 4:29 pm
by Ron Miller
I have an older Pete Jackson BB Chevy noise gear drive part # 0782-327-ICN that is missing a few pieces. The offset bushings, cam thrust bearing, and the bronze or roller thrust bearing. Will the offset cam bushing from an MR Gasket kit work? How about the cam thrust bearing, is this the common bearing used on just about every roller set? And last what about the front thrust bearing?
Thanks for looking,
Re: Pete Jackson BB Chevy noise gear drive parts missing
Posted: Mon Mar 23, 2020 5:51 pm
by ClassAct
I know the Mr. Gasket bushings work.
About the thrust bearing...I would take the gear and such down to the local bearing house and let them find something that will work.
That's all I got.
Posted: Mon Mar 23, 2020 8:50 pm
by Alaskaracer
I'd toss it and either get a quality chain or if you're set on a gear drive, a full cover style like one from Milodon. Pete Jackson drives are junk.
Posted: Mon Mar 23, 2020 9:02 pm
by GARY C
Ran one in my SBC, the harmonics separated the front main web from the block... I was warned but didn't listen.
Posted: Mon Mar 23, 2020 9:11 pm
by CGT
The Michael Jackson gear drives have better harmonics but are no longer available
Posted: Mon Mar 23, 2020 9:18 pm
by GARY C
CGT wrote: ↑Mon Mar 23, 2020 9:11 pm
There bad there bad you know it....
Posted: Mon Mar 23, 2020 9:45 pm
by Ron Miller
Guys,
Thanks for the Humor and replies.
Posted: Mon Mar 23, 2020 10:02 pm
by GARY C
Ron Miller wrote: ↑Mon Mar 23, 2020 9:45 pm
Guys,
I still have the one I ran, now I use it for mocking up a cam for the degree wheel, the crank gear is not press fit and the cam gear is drilled for degree bushings, so I can get a baseline cam install in-case I need to advance or retard crank gear before installing the actual crank gear.
Posted: Tue Mar 24, 2020 4:37 am
by Geoff2
The missing parts might be a sign....
