BOOT wrote: ↑Sat Apr 18, 2020 12:00 am 23631957_1597976350285745_7812177073960647745_o.jpg
When I adapted my current y-pipe from longer manifolds to shorter ones I did kinda the same by adding longer tube that slip fit over the old but made sure to grind down and taper the tube lip on the inside. You can see one of the new welded on ends in the pic by the floor. The main gain if any will be where I cut and fixed the Y intersection, I left some outer edge as kinda reversion step and focused mostly on the center wedge.
Most the flow in a circle is in the center on a straight shot but detail work adds up.
I still gotta finish fixing another car where they just inserted the 2.5 into a 3" and then back down to 2.5" and welded it up, the 1st part would of been fine as a reversion step but the exit not so much and it's maybe an inch or more in.
Here's a chance to tell my Hooker Horror story!Bill Chase wrote: ↑Sat Apr 18, 2020 6:01 am If you look at the cut flash that hooker and others do not remove on their headers they charge almost a grand a set for they aren't much better. I spent 2 hours with a bit extension and carbide just cleaning up the primaries at the merge to the collectors on a set of HKR-2149 super comps that are ceramic coated, the air. Tubes were welded shut, and the egr port on #7 cylinder was not cut open into the primary. Its pretty appalling what so called "American made, quality headers " look like now days.
