Found their website, I'll give them a call in the morningmt-engines wrote: ↑Mon Apr 20, 2020 7:40 pmCall up BLP.
I prefer 4150 metering for street use.
I like 2 circuit on manual transmissions because when you are say in and out of the throttle or engine braking you have a cleaner deccel especially with 2 power valves..
I did a few drag week engines that we sent out with 1500-1700 CFM dominators that were 3 circuit. But they were also bigger engines making way more power. And we're really for competition. They cruised at an rpm for long periods of time, and idled. That's about it.. Never really in and out. Huge stall converter etc.
For your price range. You can get a good one built for you. And you can just tweak it a jet or airbleed size. PV open point etc
2 vs 3 circuit metering for an auto trans road course car?
Re: 2 vs 3 circuit metering for an auto trans road course car?
- mt-engines
no problem.. i have a customer with an AED pro street dominator on his chevelle. its a Pump gas 496Bbc 10:1 with a 270@.050 .770 lift solid roller. He swapped his old one that he could never tune off(it would load up, be waay to fat in cruise or way to lean) and put the AED on it and it drove like it had fuel injection he loves it. And all the AEDs that i test on the dyno like the BLP carbs are usually spot on. within a jet change.Bwh998 wrote: ↑Mon Apr 20, 2020 8:29 pmFound their website, I'll give them a call in the morningmt-engines wrote: ↑Mon Apr 20, 2020 7:40 pmCall up BLP.
Nice. Thanks for the info man.mt-engines wrote: ↑Mon Apr 20, 2020 8:38 pmno problem.. i have a customer with an AED pro street dominator on his chevelle. its a Pump gas 496Bbc 10:1 with a 270@.050 .770 lift solid roller. He swapped his old one that he could never tune off(it would load up, be waay to fat in cruise or way to lean) and put the AED on it and it drove like it had fuel injection he loves it. And all the AEDs that i test on the dyno like the BLP carbs are usually spot on. within a jet change.Bwh998 wrote: ↑Mon Apr 20, 2020 8:29 pmFound their website, I'll give them a call in the morningmt-engines wrote: ↑Mon Apr 20, 2020 7:40 pm
Call up BLP.
- jmarkaudio
I've built up to a 2.600 blade spread base carb with 2 circuits active, adding any intermediate fuel on the dyno only hurt it. Over 1500 HP... There are a few exceptions where having the third circuit may come into play. Methanol for one, because of the sheer volume of fuel required, even then it doesn't want much. Under carb throttle stops is another, when the carb size is bigger or the owner try to lower the stop RPM too much...
Stick with 2 circuit, if you have to buy a box carb the Gen 3 950 Dominator is close on calibration. Moving the idle feed and a little emulsion cleanup and they work fine. I build almost all my new stuff with billet, it does cost a little more up front but they are a much sturdier piece. You can also get billet float bowls, and the billet parts can all be anodized for corrosion protection.
Mark Whitener
www.racingfuelsystems.com
____
____
Thanks, that's the one I was looking at.jmarkaudio wrote: ↑Wed Apr 22, 2020 10:29 am I've built up to a 2.600 blade spread base carb with 2 circuits active, adding any intermediate fuel on the dyno only hurt it. Over 1500 HP... There are a few exceptions where having the third circuit may come into play. Methanol for one, because of the sheer volume of fuel required, even then it doesn't want much. Under carb throttle stops is another, when the carb size is bigger or the owner try to lower the stop RPM too much...
Can you provide more details of the engine build? Thx - Brad
Ill provide what I know so far: either a Little M or SHP in the 400 to 440ci range, AFR 220 heads with shaft mount rockers, not sure on cam size yet but it will be a solid roller. Still undecided on intake choice too. I would like to see 700 hp at around 8k rpm.
