Port length BBC heads
How does the port length of a standard BBC say an oval port compare in length to the average standard sbc. How much longer.
Re: Port length BBC heads
Without measuring it, quite a bit......
Length of port isn't determined by shape of port...it's by the layout of the head itself......but yeah, much longer.
Mark Goulette
Authorized Amsoil Retailer
- Stan Weiss
These are from PipeMax / Larry Meaux
Int=5.339 Exh=2.818 Int=135.6 Exh=71.58 GM #3890462 SBC out-the-box shape 1.940-1.500
Int=5.975 Exh=3.380 Int=151.8 Exh=85.85 GM 781 BBC cast-iron Good-Port in ported shape
Int=5.820 Exh=3.380 Int=147.8 Exh=85.85 GM 781 BBC cast-iron Bad-Port in ported shape
Thank you lots of useful detail. So it's hard to compare the two on volume as like in velocity.
- Stan Weiss
I do not understand. You should want around the same velocity.Little Mouse wrote: ↑Wed Apr 22, 2020 6:41 pm Thank you lots of useful detail. So it's hard to compare the two on volume as like in velocity.
No different that a small valve small port SBC and a big valve big port SBC should want around the same velocity.
Stan gave you example of Port CenterLine lengths .These are from PipeMax / Larry Meaux
Example=> Roof= 4.200 + Floor= 2.200 Total= (6.400 / 2) = 3.200 Port CenterLine Length
( use Scotch 3M 218 Fine Line Tape to measure Roof and Floor Lengths )
Just measure your Port's CenterLine Length
then measure that Port's Port Volume CC's
then Flow test that Port to measure its CFM
plug all that Data into this equation to get Average CSA Velocity FPS
CSA Velocity FPS = ( Intake Port CFM * Intake Port CenterLine Length * 39.3289536 ) / Intake Port Volume CC
CSA Velocity FPS = ( Exhaust Port CFM * Exhaust Port CenterLine Length * 39.3289536 ) / Exhaust Port Volume CC
where Constant 39.3289536 = 16.387064 * 2.4
2.54^3 = 16.387064
I have a better understanding of what size heads would work well in sbc for different size engines. I'm not to deep in SBC bought parts yet. Considering doing a BBC instead. Long time ago I had a 396 and a 454 but I have a lot more experience with SBC. I did build 440 chrysler for a friends son, does this count. Lol
