AFR Enforcer SBC heads
PRH
Re: AFR Enforcer SBC heads
Post by PRH » Sun Apr 26, 2020 7:26 pm
The AFR literature says they have ductile iron seats.
The ones I’ve seen that were not from AFR “looked” to have powdered metal seats.
If you buy the AFR prepped version,it appears they come with 8mm guides.
My guess is AFR is buying the castings without seats and guides installed, and doing theirs own thing.
68maliblue
Post by 68maliblue » Sun Apr 26, 2020 8:39 pm
In my opinion the ATK aluminum SBC heads seem like a better deal. Its a Pro-Filer casting so it should be USA made. At $535 ea seems budget friendly.
65dragster
Post by 65dragster » Wed Apr 29, 2020 11:21 am
ATK only offers 70cc chambers, not 64cc.
68maliblue
Post by 68maliblue » Wed Apr 29, 2020 2:14 pm
dynoflo
Post by dynoflo » Wed Apr 29, 2020 7:04 pm
I see 64 cc for the 185 and 195 heads
https://www.summitracing.com/parts/hpe-sbc64185
https://www.summitracing.com/parts/hpe-sbc64195
i have a set of sbf enforcers coming!
dynoflo
Post by dynoflo » Wed Apr 29, 2020 7:06 pm
I have a set of SBF Enforcers coming! we'll see
65dragster
Post by 65dragster » Thu Apr 30, 2020 1:02 am
Very cool. Tell us about your build. It would be great to get your thoughts in the heads once you get them in your hands.
dynoflo
Post by dynoflo » Thu Apr 30, 2020 9:22 am
its just a street motor replacing one that blew apart. first fuel injected 5.0 i ever did. cant dyno it, am not set up for electronics. will have to rely on chassis dyno to tune. everything is done except head install and measuring for push rods. customer decided to leave it fuel injected instead of carb. ill let you know what heads are like. was told 3 weeks 2 weeks ago.
dynoflo
Post by dynoflo » Fri May 01, 2020 5:29 pm
talked to AFR. thet are sourced from china. they come with ductile seats and bronze guides. AFR does valve job, sizes guides and installs are parts. they do have 8 mm valves and Pac springs. They are behind because of the china virus. thats it until i get them.
dynoflo
Post by dynoflo » Thu May 21, 2020 5:04 pm
AFR sbf heads came today. were supposed to have 54cc chambers. AFR said deck too thin to cut. I checked deck thickness at .265. seems thin to me. going to cut .032. Not too happy about deck thickness but it is street motor so I will see. Will flow when they are cut.
PRH
Post by PRH » Fri May 22, 2020 5:21 pm
I’m detecting that some of the warm fuzzy feeling has slipped away.
What were your first impressions after unboxing and disassembling?
dynoflo
Post by dynoflo » Fri May 22, 2020 5:47 pm
never pulled a valve. fellow im doing motor for opened box read note that said couldnt cut because of thin decks. I think afr says they are .320 thick. customer took heads to be cut .030 flat deck. should be done next week. will advise as to quality and precision.
