Porting RPM
Porting RPM
Thinking of trying a RPM from a Vic. jr.. Would it be worth my effort to open it up to about 2 inches in or how far I could go?
Jim
Re: Porting RPM
Regular RPM mild 421 535hp.
Just thought I'd give it a shot might make it to the track, might not.
Jim
Re: Porting RPM
I did a RPM air gap a few years ago . The port and runners are about the same the regular RPM I believe . The runners taper down quite a bit at the flange so a good deep port match should help. Dan
Re: Porting RPM
That's what I was thinking, looks like I could get in about 2 1/2 inches or to the turn.6.50camaro wrote: ↑Fri Apr 24, 2020 9:05 pm I did a RPM air gap a few years ago . The port and runners are about the same the regular RPM I believe . The runners taper down quite a bit at the flange so a good deep port match should help. Dan
Jim
Re: Porting RPM
I just had a look at my as cast airgap
DAN is correct about taper to the flange, the outside ports go in a couple of inches then the Port becomes trapezoid in shape, measuring the width of the Port you can open at the flange and a couple of inches up the runner about 0.100" I would think as far as the Port height it is very hard to measure in my opinion.
My track testing with my combination I ran last year 383sbc 430-440hp
Airgap with one inch open spacer was quicker in the eighth mile but my Vic jnr was a couple of tenths quicker and 3 mph faster in the quarter.
Re: Porting RPM
I was wondering about rolling a 3/8ths radius from the plenum into the runners but I have no evidence for or against it.
Re: Porting RPM
access into the runners is the problem,its so damn tight.
only way really is to cut the intake down the middle ,port and tig weld back up but for what ??
the manifold of choice for me at the moment is the 300-25
Re: Porting RPM
I also did this , can not say it was a 3/8 radius but I did lay it back the best I could . Dont know if it help or not . I did all the work before running the manifold . Dan
Re: Porting RPM
I was recently rotating RPM manifold on table and could not figure out anything else to do except matching the ports to head.
Re: Porting RPM
That's more than likely what will happen, it will give me the feel good, feeling Like Steve says no room to do anything unless it gets cut in half.68corvette wrote: ↑Sat Apr 25, 2020 2:58 pm I was recently rotating RPM manifold on table and could not figure out anything else to do except matching the ports to head.
Jim
