my opinion is formed from sims in ENGMOD4T which is a virtual dyno. it comes from the observtation that if you close the inlet valve a bit earlier it doesnt just affect the IVC, it also affects the duration and centrelines so the fill at every degree from IVO to IVC changes and usually detrminantally so you end up needing a little bit of reversion to set the valve down gently and maximise trapped mass
Intake valve lift at BDC
Re: Intake valve lift at BDC
Thank you for your response, very interesting how a early intake closing can effect the entire fill cycledigger wrote: ↑Fri May 01, 2020 5:21 ammy opinion is formed from sims in ENGMOD4T which is a virtual dyno. it comes from the observtation that if you close the inlet valve a bit earlier it doesnt just affect the IVC, it also affects the duration and centrelines so the fill at every degree from IVO to IVC changes and usually detrminantally so you end up needing a little bit of reversion to set the valve down gently and maximise trapped mass
Hello Steve, the Dyno ? , not easy but ? What is Marcose Ambrose up to now days ? Cheers, Mark H. sunny central Florida.
mark,swampbuggy wrote: ↑Fri May 01, 2020 6:49 am Hello Steve, the Dyno ? , not easy but ? What is Marcose Ambrose up to now days ? Cheers, Mark H. sunny central Florida.
i am sure Ambrose has retired back to his home town,he done a short stint back in the Australian supercars but did not hang around long.
i have zero experience with dyno but i did think off that,the problem i see is in cam timing changes as in a SBC you change all events by retarding/advancing so how do you optimize IO,EXOP,EXCL before testing INCL?? its a rabbit hole at best.
for people trying to learn like myself i have to try and follow trends from people who pick lobes frequently or at least look at application,rpm ,valve size etc as has been previously mentioned,this is a good thread its just i am out of my depth
My ancient version of Dynomation certainly shows this. With IVC optimized for power at the studied RPM, cylinder pressure exceeds port pressure well before IVC and some reverse flow is seen at or nearly up to said RPM
- Stan Weiss
Bill,Stan Weiss wrote: ↑Wed Apr 29, 2020 12:07 pm How does greater valve seat angles which reduces effective curtain area at lower lifts come into play?
I believe that this has been talked about before but can not find it.
Stan
If you measure the flow / pressure in the port and now have that same flow throw a 50 or 55 degree seat @ .100" valve lift, How has the localized depression changed verses the port?
Stan
MadBill wrote: ↑Fri May 01, 2020 9:47 amMy ancient version of Dynomation certainly shows this. With IVC optimized for power at the studied RPM, cylinder pressure exceeds port pressure well before IVC and some reverse flow is seen at or nearly up to said RPM
thanks Bill,
i have engine pro sim so i will look at that and try and make some sense of it.
i was just reading what Bob Hoff put up on the other thread about cam lobes with opposite ramps which adds a new mix in the equation
