Water injection
Water injection
How many of you use water injection. Haven’t really read up or used it. Whats the idea of it and what gains to expect. I see these B/t heads made for it?
Re: Water injection
Thanks Paul. These heads have bungs for them so was curious. Read about it years back but never looked into it.
Re: Water injection
Good advice, but questionable factoid. Water is an octane booster?
Re: Water injection
Not really a booster but a AF coolant to aid in detonation resistance.
It's common in truck and tractor pulling when 2 turbos, a primary feeding a secondary pushing 140psi of boost into a inline 6 cylinder diesel. I like watching them and have a couple friends compete but I don't know much about the specifics. I'm sure a pulling engine specific shop could answer some basic questions as most seems pretty chill. The others act like gods.
Re: Water injection
If I ever get a blower on my BBC 427, I'm planning on using water meth injection.
- New Member
Re: Water injection
I run a self built water injection system on my non intercooled twin turbo engine which allows me to use 12 psi boost on 91 octane. It will only take 8 psi and not detonate without the water and the same timing locked at 20 degrees and this is straight water, no meth.
Your results may vary...
Re: Water injection
Are you using a pump, or is your system boost driven?Firechicken wrote: ↑Sun May 10, 2020 1:17 am I run a self built water injection system on my non intercooled twin turbo engine which allows me to use 12 psi boost on 91 octane. It will only take 8 psi and not detonate without the water and the same timing locked at 20 degrees and this is straight water, no meth.
- New Member
Re: Water injection
120psi pump to misting nozzles activated in 2 stages with Hobbs switches and water solenoids. Just a large windshield washer fluid tank with a low level indicator light mounted to the A pillar.
Pump and tank in the trunk.
Re: Water injection
I am still torn between a boost powered system and a Hobbs triggered pump set-up. what pressure are your switches set at?Firechicken wrote: ↑Sun May 10, 2020 5:24 pm 120psi pump to misting nozzles activated in 2 stages with Hobbs switches. Just a large windshield washer fluid tank with a low level indicator light mounted to the A pillar.
I was also thinking about using a Hobbs switch to close the pink wire on a MSD digital 6, to add a little retard at around 12 psi for extra insurance, with water injection coming in at 6, but it looks like most guys that use water/meth don't use any retard. I am looking at around 15 psi on Chevron 94, with an 8.2/1 mechanical compression ratio. Cam is fairly big for a blown street motor, 256/263 @.050
Re: Water injection
I used a Snow variable flow rate unit on detonation prone N/A street engine...The engine detonated at full throttle when passing through the torque peak....It worked ok...I used about 50 percent alcohol...I never noticed any power increase but to be honest I didn't mess with jetting too much....
Re: Water injection
Perhaps "Karl" was also equipped with WEP to dominate the Autobahnen -- Remarque (1936) does not share this with us.Drei Kameraden wrote:But the man did one more thing. He could not resist revenge. He motioned for us to follow. He even waved particularly carelessly and confidently. "Otto!" Said Lenz warningly.
But he didn't have to say anything. Karl jumped at the same moment. The compressor whistled. And suddenly the waving hand disappeared in the window - because Karl followed the request; he came. He even came inexorably, he caught up with everything - and now, for the first time, we took notice of the strange car. We looked up at the man behind the wheel, questioning innocently; we wanted to know why he waved to us. But he looked convulsively to the other side, and Karl was only now pulling away with full throttle, staring at dirt, with waving fenders, a victorious dirtchip.
https://en.wikipedia.org/wiki/War_emergency_power
- New Member
Re: Water injection
falcongeorge wrote: ↑Sun May 10, 2020 5:33 pm
I spray water after the turbos so it needs more than boost pressure to push it. With a pump you can get the water to mist nicely.
1st stage hits at 6psi with 300cc/min.
2nd stage at 10psi with a 500cc/min nozzle.
8.2:1 462 ci
Cam is HR 224/224 114ls installed at 114.
Small turbos needed help as they spool really fast and I don't use any type of timing control.
Re: Water injection
I am using a roots so I will be spraying it above the carbs, the boost driven system is tempting, as theoretically at least, the flow should rise more or less lineally with manifold pressure?? I was going to use these nozzles, as they are supposed to atomize relatively well at lower pressures. Its mostly the import guys that seem to have a reasonable knowledge base in this area, But most of them aren't running 6-71's on Ford FE's. Go figure.... .Firechicken wrote: ↑Sun May 10, 2020 7:19 pmfalcongeorge wrote: ↑Sun May 10, 2020 5:33 pm
8.2:1 462 ci
https://www.ispray.com/ecatalog/flat-sp ... VVA-730116
- New Member
Re: Water injection
Boost pressurized systems can work well and have been used successfully. They can be extremely simple and trouble free once you have flow rates sorted out and a safe guard in place to stop any chance of siphoning or vacuum induced flow.
There is some good information on this in an old school book called Turbochargers by Hugh MacInnes that could help you if needed.
