Page 1 of 1
Msd 8991 / French grimes timing light
Posted: Sun May 10, 2020 8:18 pm
by houser45
Msd 8991 self powered timing light. I need to retro fit a new aaa battery holder for it or buy a rechargeable pack for it. Does any body know how many volts the original pack for the 6 aaa batteries is wired for? Or could someone check theirs? My original holder is long gone
Re: Msd 8991 / French grimes timing light
Posted: Sun May 10, 2020 11:02 pm
by ProPower engines
houser45 wrote: ↑Sun May 10, 2020 8:18 pm
I would call Grimes directly and ask. If they are working these days that would be the best bet.
They may also offer an updated battery pack.
Posted: Mon May 11, 2020 9:54 am
by RCJ
Aaa are 1.5 volts.installed in series ,wouldn’t that be 9 volts
Posted: Tue May 12, 2020 11:20 am
by Protech Racing
Start with 3 V , add on until it works . Under 9V
Posted: Tue May 12, 2020 10:21 pm
by Tuner
The compact Kowa Seki timing light uses two AA for 3V and has a brighter flash than regular 12V powered lights. Without having the battery holder for yours so you can figure out if the batteries were wired in parallel for longer battery life or series for higher voltage, be careful not to over-voltage and kill it. It could be two trios of 3 each AAA = 3 Volts, or 3 pairs of 2 each = 4.5 Volts, or all 6 in series for 9 Volts. I would rig it with jumper wires and start with two AA to see if that makes it function with normal brightness.
Posted: Tue May 19, 2020 9:37 am
by leahymtsps
RCJ wrote: ↑Mon May 11, 2020 9:54 am
X2
I just checked 1 and it's 9 volts.
Tom
Posted: Tue May 19, 2020 11:53 am
by houser45
Thank you
