Oil pressure vs volume
Kevin Johnson
Re: Oil pressure vs volume
Post by Kevin Johnson » Thu May 21, 2020 1:04 pm
You just need to put some fine directional screening over that area. If you measure the box and approx. size of the sump well I will make you something (no charge).
A few years back, Yves had a similar issue.
PM me the measurements and your address.
Steve.k
Post by Steve.k » Thu May 21, 2020 1:21 pm
Ok thanks Kevin I’ll get measurements later today. Im more than happy to pay you for your help and expertise.
piston guy
Post by piston guy » Thu May 21, 2020 4:05 pm
Steve I use two cover plates on my pumps as a dormer Ford engineer told me they found as the pressure increased , the cover would flex and bleed off pressure. Simple virtual no cost and I did see better pressure because of it. I do it to all of my pumps ( even aluminum ) except obviously those with a lower bearing and 429-460 "cover feed" pumps.
allencr267
Post by allencr267 » Thu May 21, 2020 4:41 pm
...the cover would flex and bleed off pressure.
Thanks.
Super duper helical gotta be more, the reason some swear HV's necessary? :wink:
tuffxf
Post by tuffxf » Thu May 21, 2020 4:43 pm
Been running the two cover plates on mine forever as well, good thing.
Steve have you verified lifter to lifter bore clearances?
Correct me if I’m wrong, this engine of yours would it be the first one that is up and running with any real dyno time on it?
Cheers
allencr267
Post by allencr267 » Thu May 21, 2020 4:47 pm
F'up blanked
Steve.k
Post by Steve.k » Thu May 21, 2020 4:57 pm
Cheers
I’ll confirm that got to get to my notes. Yes very first one. Approximately 50 dyno runs now.
tuffxf
Post by tuffxf » Thu May 21, 2020 5:38 pm
Thats cool! :)
Be interesting to see how it turns out bottom end wise, your the test pilot!
Do they have an oiling diagram for these or is it identical to 351w
Cheers
Steve.k
Post by Steve.k » Thu May 21, 2020 7:58 pm
They are identical. Lifter bore looks to be a smidge over .001.
tuffxf
Post by tuffxf » Thu May 21, 2020 8:22 pm
ok thanks,
A smidge over .001, is that measured ?
Must be similar to a mick hair! :D
Steve.k
Post by Steve.k » Thu May 21, 2020 9:36 pm
Gets above 1.5 i get worried. Anything in between good.
Steve.k
Post by Steve.k » Thu May 21, 2020 10:03 pm
Just pulled some rod bearings to check all perfect after 27 pulls on dyno.
tuffxf
Post by tuffxf » Thu May 21, 2020 10:33 pm
very good!
Steve.k
Post by Steve.k » Thu May 21, 2020 10:36 pm
Never heard that before Randy. I could try it. By the way your pistons worked awesome in this unit. Thanks again.
Steve.k
Post by Steve.k » Fri May 22, 2020 12:50 pm
Excuse dirty pan. Everything going in parts washer shortly.
