How to fix a crack in cast alu intake?
Nut124
Post by Nut124 » Wed May 13, 2020 4:47 pm
So, I managed to port an alu intake to the point where I see a tiny crack and some daylight.
This was a thin spot, casting defect, that I did not pay attention to.
How to repair? Weld? Epoxy? The hole is not a structural concern. Just cannot have a leak there.
ProPower engines
Re: How to fix a crack in cast alu intake?
Post by ProPower engines » Wed May 13, 2020 9:32 pm
The best way is to weld it!
Epoxy will do the job but not forever. It is easier and faster if its on the engine already but if not weld it =D>
jeff swisher
Post by jeff swisher » Wed May 13, 2020 11:16 pm
I have used JB weld inside of carburetors and on outside of aluminum carburetors to fasten on a fuel inlet.
I have never had the Old recipe JB weld come off.
I do not sand it though.
I form it after it begins to set up and leave that slick sealed outer sheen or coating it develops.
Do not use JB Quick.
I have also used JB Weld where the pipe threaded coolant fitting goes in.
I have had friends tighten their fitting too much and crack the casting in that area.
I clean and swab the area and apply JB Weld into the threads and then onto the threads of the fitting and screw them together.
Let set up at least 24 hours before putting into service.
But like was stated if you can weld the area that of course would be best.
Baprace
Post by Baprace » Sat May 16, 2020 6:07 am
Nut124 You have an email.
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Sat May 16, 2020 6:38 am
Not a big deal. Stick your grinder in the hole and go round and round until you have about .100 wall thickness. Cut and form a piece of 1/8'' metal to fill the hole. Have a TIG guy weld it for you and touch up with your grinder. It happens...be glad it's not iron!
Bill Chase
Post by Bill Chase » Sat May 16, 2020 10:25 am
You could make the hole bigger and mix up some jb weld, while working it make it have some area inside and outside of the port, that would essentially lock the epoxy in place and if it did come loose it wouldn't fly into the head, it would be trapped..
But I agree, this is a 5 minute job for a decent tig welder. Probably minimal cost. And would be the best repair.
