Mark IV BBC cam bearing orientation
I noticed on my 454 block the center cam bearing housing has a groove machined in it-I could clock that bearing oil feed hole at 3 oclock? Would there be any advantage to doing this with all of them?
Pro question poster.
Re: Mark IV BBC cam bearing orientation
If the block isn't grooved, you can take a die grinder and burr and grind a shallow groove in the od of the bearing, about .020-.030" deep, about the same width of the oil hole. Best place to clock the oil hole in a cam bearing is to clock it at approx 4 o'clock. This makes sure the cam is traveling on the oil wedge. Should have been done like this from the factory. As to the housing of your setup, go for it....
Mark Goulette
Authorized Amsoil Retailer
Sure, why not, not that better then adequate vs advantage makes every thing feel more comfortable for you even if it lessens the flow everywhere else.Would there be any advantage...
How well finished are the bearings outlet?
IDK Mark IV BBC, does #3 also feed anything?
You can only do that when there is an annulus behind the bearing; whether it is already there or you machine it there.Bob Hollinshead wrote: ↑Sun May 24, 2020 11:19 am I noticed on my 454 block the center cam bearing housing has a groove machined in it-I could clock that bearing oil feed hole at 3 oclock? Would there be any advantage to doing this with all of them?
Otherwise you simply need to align it with wherever the oil supply hole is located.
Sometimes there is an annulus machined into the backside of the bearing.
number 3 and number 5 have the annulus machined, 1,2, & 4 do not but it would be easy enough to make that groove to the 3 or 4 o'clock position or make a short groove on the bearing backside. It makes sense to do it I think but it it's not eating up bearings there isn't an issue right?Walter R. Malik wrote: ↑Sun May 24, 2020 4:50 pmYou can only do that when there is an annulus behind the bearing; whether it is already there or you machine it there.Bob Hollinshead wrote: ↑Sun May 24, 2020 11:19 am I noticed on my 454 block the center cam bearing housing has a groove machined in it-I could clock that bearing oil feed hole at 3 oclock? Would there be any advantage to doing this with all of them?
Durabond CH12B has a grove machined in the back of the bearing already if you want to save some time.
Grooving the bearings and orienting the holes in the 3-4 o'clock position will not affect oil flow to anything else, it will remain the same. Repositioning the hole improves the oil wedge that the camshaft rides on, nothing more. I don't know of any engine builders that clock the bearings directly in line with the oil holes anymore.allencr267 wrote: ↑Sun May 24, 2020 4:23 pmSure, why not, not that better then adequate vs advantage makes every thing feel more comfortable for you even if it lessens the flow everywhere else.Would there be any advantage...
Mark Goulette
