Weird colored reversion.
77cruiser
Post by 77cruiser »
Why is it this color?
Jim
Ericnova
Re: Weird colored reversion.
Post by Ericnova »
Are you using an octane booster with MMT in it??
77cruiser
Post by 77cruiser »
Ericnova wrote: Thu May 28, 2020 8:55 am Are you using an octane booster with MMT in it??
No non oxy pump. Yea looks like my plugs did when I dynoed it & we put some race gas booster in it.
Jim
CGT
Post by CGT »
I agree looks like MMT, but not to sidetrack...I'd be interested in knowing more about the engine combination, in that why its getting so much reversion.
PRH
Post by PRH »
Looks more like staining than reversion to me.
It’s mostly on the secondary side....... even in the spacer, with what appears to be a spread bore carb...... so most of the fuel is coming from the secondary side of the carb.
77cruiser
Post by 77cruiser »
421 sbc 9.8 cr
Ported Profilers,ported Vic.Jr, by Eric Weingartner
Straub cam 227/239/107 103ICL
Quadrajet
my homebuilt 421 headers
Jim
BOOT
Post by BOOT »
PRH wrote: Thu May 28, 2020 4:08 pm Looks more like staining than reversion to me.
Yah looks that way to me to. I have a couple dual planes with signs of reversion in the intake, pretty even up the runners, doesn't make it to either plenum side(I know singe plane is not the same n prob worse). Still the heads were worse/darker than the intake.
77cruiser
Post by 77cruiser »
I've never seen that color from pump gas before. What would be in it to make that color? A mile farther north I'd say colour. :)
Jim
Geoff2
Post by Geoff2 »
Temperature related? [ Temp of the intake manifold itself ]. Would the colour be darker, nearer to black, if the intake was hotter/heat soaked?
Ron Miller
Post by Ron Miller »
What size are the header tubes and what header flange?
Ron Miller
77cruiser
Post by 77cruiser »
Ron Miller wrote: Sun May 31, 2020 12:32 pm What size are the header tubes and what header flange?
1 3/4 D port flange.
Jim
Calypso
Post by Calypso »
PCV into the rear of the carb?
77cruiser
Post by 77cruiser »
Calypso wrote: Sun May 31, 2020 5:01 pm PCV into the rear of the carb?
No front.
Jim
