602 Crate Engine piston ring question
What are the thickness dimensions of the three rings as engineered by GM ? Thanks Mark H.
Re: 602 Crate Engine piston ring question
What year 602 as there not all the same?swampbuggy wrote: ↑Sat May 30, 2020 10:25 pm What are the thickness dimensions of the three rings as engineered by GM ? Thanks Mark H.
Tom
Leahymtsps, sorry it took so long to respond, the pistons are in an engine that was purchased 6 months ago. Mark H.
just went though this last week on a 350 Chevy ,,I checked pistons on UEM/Silvolite and there's about 25 different pistons for 350 Chevys lots of different ring combos the ones that were ordered were STD 139 Hastings and were wrong 5/32 5/32 3/16 found the same rings were used in this engine with the same top rings and shallow 3/16 oil rings,, but also have a couple of different metric sizes,, the only way to know for sure is to measure them and the depth of the ring lands to be sure..
If it's that new, it should have a metric ring pack 1.5-1.5-3 mmswampbuggy wrote: ↑Sun May 31, 2020 10:09 pm Leahymtsps, sorry it took so long to respond, the pistons are in an engine that was purchased 6 months ago. Mark H.
Tom
I have a set of those pistons that are 2mm,1.5mm and 3mm.
depending date manufacture ... I've seen 602 with
1.5, 1.5, 3.0
2.0, 1.5, 4.0
5/64, 5/64, 3/16
https://staffordmotorspeedway.com/wp-co ... MANUAL.pdf
1.5, 1.5, 3.0
2.0, 1.5, 4.0
5/64, 5/64, 3/16
Thanks to all of you Folks who give me input, i will see for sure when i get them in my hands. Mark H.
maybe too late to reply but when i was cheating them up i called Mahle and they had replacements. Dont remenber ring pack.
As has been stated in previous posts, the only way to determine the ring pack used in a crate engine is to remove a piston and measure the ring grooves. Specs are often changed quite often when crate engines are designed and/or updated.
Bill
SAE Member (30 years)
