602 Crate Engine piston ring question
swampbuggy
Post by swampbuggy »
What are the thickness dimensions of the three rings as engineered by GM ? Thanks Mark H.
leahymtsps
Re: 602 Crate Engine piston ring question
Post by leahymtsps »
swampbuggy wrote: Sat May 30, 2020 10:25 pm What are the thickness dimensions of the three rings as engineered by GM ? Thanks Mark H.
What year 602 as there not all the same?
Tom
swampbuggy
Leahymtsps, sorry it took so long to respond, the pistons are in an engine that was purchased 6 months ago. Mark H.
jred
Post by jred »
just went though this last week on a 350 Chevy ,,I checked pistons on UEM/Silvolite and there's about 25 different pistons for 350 Chevys lots of different ring combos the ones that were ordered were STD 139 Hastings and were wrong 5/32 5/32 3/16 found the same rings were used in this engine with the same top rings and shallow 3/16 oil rings,, but also have a couple of different metric sizes,, the only way to know for sure is to measure them and the depth of the ring lands to be sure..
leahymtsps
swampbuggy wrote: Sun May 31, 2020 10:09 pm Leahymtsps, sorry it took so long to respond, the pistons are in an engine that was purchased 6 months ago. Mark H.
If it's that new, it should have a metric ring pack 1.5-1.5-3 mm
Tom
rfoll
Post by rfoll »
I have a set of those pistons that are 2mm,1.5mm and 3mm.
leahymtsps
rfoll wrote: Mon Jun 01, 2020 10:46 am I have a set of those pistons that are 2mm,1.5mm and 3mm.
Those are for a 604 not a 602
Tom
rebelyell
Post by rebelyell »
depending date manufacture ... I've seen 602 with
1.5, 1.5, 3.0
2.0, 1.5, 4.0
5/64, 5/64, 3/16
https://staffordmotorspeedway.com/wp-co ... MANUAL.pdf
swampbuggy
Thanks to all of you Folks who give me input, i will see for sure when i get them in my hands. Mark H. :)
dynoflo
Post by dynoflo »
maybe too late to reply but when i was cheating them up i called Mahle and they had replacements. Dont remenber ring pack.
engineguyBill
Post by engineguyBill »
As has been stated in previous posts, the only way to determine the ring pack used in a crate engine is to remove a piston and measure the ring grooves. Specs are often changed quite often when crate engines are designed and/or updated.
Bill
SAE Member (30 years)
