Aussie burnout engine bearing clearances?
shoedoos
Post by shoedoos »
Anybody know what clearances the Aussies run in their blown, injected big block Chevy burnout engines?
engineguyBill
Re: Aussie burnout engine bearing clearances?
Post by engineguyBill »
I have no idea what these blokes run for bearing clearance, but cannot see any reason why they would not be running the generally-accepted bearing clearances of .0025" to .0003" OR possibly .0035" to .0004".
Bill
SAE Member (30 years)
MELWAY
Post by MELWAY »
I have run .003-.0032 rods. And .0035 mains
I have heard of others pushing mains to .004
KnightEngines
Post by KnightEngines »
Yeah, I'd be closer to .004" on the mains & .003-.0033" on the rods.
shoedoos
Post by shoedoos »
cheers guys, any other tricks in keeping one alive? EFI BIg-ugly/14-71 on top of a 427....
lefty o
Post by lefty o »
id sure be on top of windage control, and keeping oil in the pan, ie kickouts.
shoedoos
Post by shoedoos »
Moroso 21049 pan okay? Or should I be looking at a road race style?
MELWAY
Post by MELWAY »
Something like that MUST have a dry sump.
I have done many burnout engines. And as soon as you go hat with methanol. It tops them over the edge with wind age and oil control
Also what ign system have you got? Weak spark can cause major issues
FC-Pilot
Post by FC-Pilot »
MELWAY wrote: Wed Jun 17, 2020 10:20 pm Something like that MUST have a dry sump.
I was thinking the same thing in regards to oil control. After running injected alky drag stuff, I can’t imagine the oiling issues those things have. Also with a dry sump and good preheating and maybe even pulling vacuum it could keep the oil Stay much cleaner without fuel contamination, therefore helping the oil to continually do its job.
shoedoos
Post by shoedoos »
coil on plug through a Link ecu, Moran injectors, staying wet sump....not a dedicated burnout car, just adding insurance with clearances and any other tips etc
MELWAY
Post by MELWAY »
How hard do you rev it. Is it on e85 or meth
shoedoos
Post by shoedoos »
Melway, the thing is being built at present, that's why any tips would be appreciated, presently methanol, but may change to E85. RPMs aren't going to be any where near the Aussie stuff, it has one of those flexy OEM steel cranks in it....more like 5k, blower 10-percent overdrive.
MELWAY
Post by MELWAY »
I have run those GM steel cranks at 1000hp with no issues they are a good thing with a nice radius on journals
shoedoos
Post by shoedoos »
how about piston to head clearance?
shoedoos
Post by shoedoos »
...also piston to wall clearance as well - would you open them up a bit from manufacturer spec? Any special coatings on the pistons?
