Straight through mufflers
Ladderbar
Re: Straight through mufflers
Post by Ladderbar »
You need to try Borla's you will like the performance and the way it will run and sound.
Post by F-BIRD'88 »
GT50 wrote: Fri Jun 19, 2020 5:55 am
F-BIRD'88 wrote: Fri Jun 19, 2020 12:27 am Have someone else drive the truck so you can evaluate the exhaust tone from outside at a distance...
There is a sweet sounding exhaust , then there is is a exhaust that just pisses every one off, including you eventually..
If the exhaust terminates under the truck VS at the rear bumper it is going to get old quick... The H pipe is a good idea.. I build my own custom mufflers.
Look what Ford did with the late Mustangs..
I took a California Special 6 Speed rag top for a ride .
As soon as you fire it up... Its like " Ya Baby"!!! (Austin Powers) ♪♪♪🇬🇧
Can you show the inside of your custom muffler? If it's not top secret.
You need LEVEL #5 clearance ha ha
Give me a bit and I will dig up a drawing..
Post by F-BIRD'88 »
What about the old SONIC TURBO mufflers?
Do they still make those?
Post by F-BIRD'88 »
The Sonic Turbo is similar to my custom muffler.
Its not exactly the same but uses similar ideas.
I had not seen the guts of a sonic turbo when I did mine.
I think these are good.. My custom mufflers worked very well..
http://www.studiodino.com/images/muff_box.jpg
Post by F-BIRD'88 »
My 88 Firebird had a pair of my custom built mufflers 2.5" in out
https://youtu.be/YEOR_5SO2-8
Had a aggressive idle but nicer and quieter than flowmasters. Not over the top when @Wot either..
Same drag perf as open headers. Actually just a hair quicker.
Best with headphones
tjs44
Post by tjs44 »
on both sizes of STs the drone was at 1900-to 2100ish.None up to it and none after it.My car has a TKO and that is where I drive it on the highway and in 4th at 2000 on city streets!The 14in was 86 decibels at 2000 and the 18s were 84.I now have a set of just non performance 18s and they are 82.Im might try the HPs and if they suck I might change my 3.31s to like 3.55s to keep me out of that range.Tom
bob460
Post by bob460 »
Post by MadBill »
I can't imagine those slits sucking up much sound... :shock:
GARY C
Post by GARY C »
Let it breath... :)
bob460
Post by bob460 »
MadBill wrote: Fri Jun 19, 2020 11:31 pm I can't imagine those slits sucking up much sound... :shock:
Dumped at the diff 3 inch with x-pipe......
https://www.facebook.com/10052891829353 ... ideos_card
With tail pipes 3.5 inch with x-pipe......
BOOT
Post by BOOT »
If you watch Roadkill then you know of the Muscle Truck, it used larger straight thru mufflers like mention in an earlier post but I think they went a bit larger and it's deff loud!
RevTheory
Post by RevTheory »
A crossover will really pull some snap out of loud mufflers.
Steve K
Post by Steve K »
I run 3" Ultra Flows with no cross over and dumps at the axle on my 79 Camaro with a pretty hot Tunnel Rammed 427 SBC. Its pretty loud. I did run 3" bullets before with a 406 I had in it and that was way beyond what I would consider acceptable as far as noise goes, didn't care much for the tone either. So one morning when I woke up at 4 am wondering what the f*%$k am I going to do now, I figures why not try the bullets in front of the Ultra Flows, so I welded them up and it actually tones it down a bit, as a nice aggressive idle still but less of a cackle to it. On the highway it's pretty quiet till you put your foot in it. I also like the fact that there is no comprise in back pressure with this set up. This is purely a street car.
Fireonthemountain
Post by Fireonthemountain »
The Sonic Turbos were basically now what we call the Dynomax Super Turbos, with both using a noise or energy cancelling bulge, at the end of the intake tube of the mufflers. Both of these mufflers will get a little louder with time/running them over months. Don't forget the Walker Quiet-Flow mufflers, which can have an even longer case than their Dynomax Super Turbos.
For both noise control and increased flow, if someone has room, then more that 2 mufflers can be used in parallel.
Belgian1979
Post by Belgian1979 »
I recently installed the inserts in the exhaust tips. I didn't expect a lot but they did reduce sound end drone. Only drawback is that at idle it produces this kinda plopping sound, like it's loose, which it is not.
There was a slight drop in power across the board as I had to retune my efi. But only a couple % so not to bad.
