Edelbrock E force heads #5089
gordon
Post by gordon » Fri Jun 19, 2020 11:23 am
Got a set of these heads with the intent to put them on a hyd FT cammed 383 sbc for a truck (58GMC) . First three blocks I had cleaned and checked were cracked, latest one is a 1989 roller block . Waiting to hear back from shop as to pass or fail for use. If it is a go then I would like to use a mild hyd roller cam since block is a roller style block. Since Edelbrock says not for roller use ,what would it take to make these heads work with mild hyd roller cam , parts and labor $$$? If necessary I will ditch these and get some more expensive heads already set up for the Hyd roller combo. Looking at the TFS aluminum heads that look like the old double hump units. Flow numbers looked good for small runner heads. Idle to 5500 max. not a rumpty rump set up. I think TFS 3021007 or 3021006 I was told these are USA castings.
af2
Re: Edelbrock E force heads #5089
Post by af2 » Fri Jun 19, 2020 11:45 am
Put some good springs on them and run the hydro roller.
They are a decent head for what you are doing.
If you run out of options on a block, I have a few good ones.
GURU is only a name.
mag2555
Post by mag2555 » Fri Jun 19, 2020 12:17 pm
X2!
Change out the springs for a good set of Manlys and for sure then confirm your coil bind clearance and retainer to seal clearance both for the lift your choosen Cam has and shoot for 140 psi on the seat.
65dragster
Post by 65dragster » Fri Jun 19, 2020 12:47 pm
So, I have a set of these E Force heads (came on a motor I bought) but they are earlier version with Edelbrock #6088 casting number. My understanding is that Edelbrock sells the castings to EPWI and they sell to machine shops complete or as a bare casting. Mine are complete, supposedly with a hydraulic roller spring good to .570 lift. Rex Hutchinson machine shop did a light pocket port job and did cartridge roll work to clean up the intake ports. I haven't had the heads flowed, but they look like a decent street head. Does anybody have experience with these?
Coloradoracer
Post by Coloradoracer » Fri Jun 19, 2020 12:53 pm
Agreed, proper springs for the cam you choose and you're good.
Mark Goulette
Authorized Amsoil Retailer
rebelyell
Post by rebelyell » Fri Jun 19, 2020 1:18 pm
Compare:
chevy performance 350/357 has iron vortec heads with 10212811 spring; a plain jane vortec single w/ 80 lbs on seat
along with 12677151 hyd ROLLER cam 215*/223* .473"/.473". That spring is only ~ 80 lb on seat & ~ 256 lb open
have little doubt your edelbrock springs are as strong if not stronger. GM engineers know more about this than I do.
https://paceperformance.com/i-6484546-1 ... ingle.html
https://www.chevrolet.com/content/dam/c ... 367080.pdf
BTW, the OE Roller Lifters are considerably lighter than typical link-bar retro-rollers lifters; lighter requires less spring to control its mass.
gordon
Post by gordon » Fri Jun 19, 2020 1:30 pm
My big concern was their (Edelbrock) comment to me that I would experience seat failure due to closing rate of valves being more aggressive even on the milder hyd roller cams.
rebelyell
Post by rebelyell » Fri Jun 19, 2020 1:39 pm
Perhaps GM engineers forgot all about that.
rebelyell
double post
gordon
Post by gordon » Fri Jun 19, 2020 5:19 pm
Info in box with heads : spring dia. 1.460"
Installed @ 1.800"
seat pressure 125 lbs.
@ .500" lift 320 lbs.
Max rec. lift .550"
Then in several places on info sheet says Not compatible with Hyd. roller cams.
Tech at Edelbrock on phone said powdered seats used in head will not take the impact loads of Hyd. roller cams. today. So I am curious as to price of putting better seats in these heads and maybe better springs and valves.
af2
Post by af2 » Fri Jun 19, 2020 5:22 pm
Installed @ 1.800"
Max rec. lift .550"
Wrong!!!
rebelyell
Post by rebelyell » Fri Jun 19, 2020 5:40 pm
Tech is wrong when he told you a weaker spring would cause valves' closing rate to be more aggressive. Incredible! Tech either flunked freshman physics (hooke's law - young's modulus) or has No practical valvetrain experience -- or both. Really?? It's the stronger spring that both accelerates valve toward seat at faster rate and slams it shut that much harder; Not the weaker spring. Next thing tech's gonna tell ya: he's Vic himself.
Differences in those e-street heads are the different springs' strengths (psi etc); not their seats
Post by MadBill » Fri Jun 19, 2020 10:39 pm
Unless the valvetrain loses control*, is it not the lobe profile (and RPM) that determines the contact velocity? (*And of course a too weak spring is a major cause of same.) :-k
Post by F-BIRD'88 » Sat Jun 20, 2020 12:42 am
There are lots of hyd rollers that will work with those springs.
1980RS
Post by 1980RS » Sat Jun 20, 2020 3:25 pm
Installed @ 1.800"
Max rec. lift .550"
Talking with an Edelbrock Tech on stuff is like talking to a brick wall. You will get a better answer from the wall. When I got a badly machined intake form them a few years ago it was like trying to pull teeth to find someone there who had any type of mechanical aptitude. Unbelievable with a company like Edelbrock.
