SAM's SB2 At The EMC And The REC
Gregory
Post by Gregory »
Here's the pop quiz for the week:
The School Of Automotive Machinist (SAM) came in a close second at the 2012 EMC with their 402 cu in SB2 in the Xtreme Street class.
The same engine was entered in the Race Engine Challenge (REC) in 2019 with only the following differences:
* The 2012 EMC engine had 15:1 compression, .800 lift (net I assume since there was no lift rule) and a tub oil pan.
* The 2019 REC engine had 11:9 compression, .775 zero lash cam lift rule and a stepped oil pan.
Yes they were on a different dyno, but we are confident they were both calibrated correctly.
Question: How much power did it lose in 2019 and how much average power did in lose between 4,000 and 7,500 RPM's.
What's your guess? The answers may surprise you and will be posted in a couple of days.
www.RaceEngineChallenge.com
408 Nova
Re: SAM's SB2 At The EMC And The REC
Post by 408 Nova »
SAM's SB2.2 won Xtreme Street in 2012.
Gregory
Post by Gregory »
Correction: It was 2011 when they came in second. They won with that engine in 2012 when the RPM was upped to 8,000 RPM.
bob460
Post by bob460 »
Gregory wrote: Fri Jun 19, 2020 3:01 pm Here's the pop quiz for the week:
So how much power did it lose........ if any?
David Vizard
Post by David Vizard »
I think some might question my eligibility to guess at this since I have experience with both dyno's. I know the UNO dyno read slightly high for the 2012 shootout as we had an engine on it for another project for my BBC book - all to do with ex pipe lengths.
I am sort of hoping some of my critics may make a guese here to see if they show me up. Lets see. Anyway my guess here is about 30 Hp on peak with, over the test range involved, about 12 hp average. Now lets see if 500,000 plus dyno pull experience earns me any credits.
DV
gmrocket
Post by gmrocket »
-45.1 peak hp
-17 tq or -15.9tq eliminations and during the week
D
Walter R. Malik
Post by Walter R. Malik »
David Vizard wrote: Tue Jun 23, 2020 5:22 pm I think some might question my eligibility to guess at this since I have experience with both dyno's. I know the UNO dyno read slightly high for the 2012 shootout as we had an engine on it for another project for my BBC book - all to do with ex pipe lengths.
DV
David, I don't know about dyno compatibility and the differences you found but, these were the numbers posted.
At the 2011 EMC Contest
... 813.1 H.P @ 7,100 RPM
... 660.0 lb/ft Torque @ 5,900 RPM
At the 2019 REC Contest
...780.8 H.P. @ 7,000 RPM
...644.1 lb/ft Torque @ 5,900 RPM
gmrocket
Post by gmrocket »
best hp number i found for the 2019 rec was 788 for sam
CGT
Post by CGT »
The EMC dyno calibration has been all over the place through the years....
hoffman900
Post by hoffman900 »
CGT wrote: Wed Jun 24, 2020 9:15 am The EMC dyno calibration has been all over the place through the years....
This was my first thought when seeing the question.
Tuning 101, don't compare dynos.
-Bob
Walter R. Malik
Walter R. Malik wrote: Tue Jun 23, 2020 8:02 pm
These numbers were the posted average of the 3 best runs.
CGT
Post by CGT »
The cool thing about a dyno competition is that everyone competes on the same dyno regardless of how it reads... If you cant cut the mustard, there are no excuses or reasons to reference other dyno's.(although some make plenty)
bob460
Post by bob460 »
DV
Only 2.3hp off.......WOW..................the 500k plus pulls have paid off......nice work!!
How close could you get with a dyno proven combo if i gave you the specs?
Warp Speed
Post by Warp Speed »
500,000+ dyno pulls = 27+ pulls per day, 7 days a week, 365 days a year for 50 years.
Impressive!
hoffman900
Warp Speed wrote: Thu Jun 25, 2020 5:00 am 500,000+ dyno pulls = 27+ pulls per day, 7 days a week, 365 days a year for 50 years.
Impressive!
According to his book published in 2010, it was 200,000 :?
-Bob
Locked
