low buck 454
Re: low buck 454
I have a 10.3-1 460 with pocket ported buy stock valve 049 heads and that cam, except mine is a roller. It does not impress me. Although it has a Team G single plane, [should have a RPM], I blame the cam. It does sound like a bad mo-fo.
The late MKIV 454s and the Gen 5s had a small dish. The Gen 6s have a 2 valve flat top.
5 and 6 are one piece rear seal. 6s have provisions for roller cam. Neither 5 or 6 have a fuel pump boss, unless it was a crate engine or a replacement engine.
There are differences in the coolant passages. You should figure out what you have. If you post the block casting #...…
Dave
Dave
Re: low buck 454
i think its a gen V
it has no fuel pump boss, not set up for roller cam, it has 1 piece seal and the casting number is 10114182
- mt-engines
Re: low buck 454
Yes it will. A tad over.prairiehotrodder wrote: ↑Fri Jun 19, 2020 6:04 pm I picked up a TBI 454 that has been recently rebuilt with .030 over speed pro Hyper pistons (stock style dish) and its got low miles and looks mint inside. It has the Gen ? whatever block with 4 bolt mains. Sorry i never understood roman numerals.
Anyways i had a plan to build it into something fun. Here is what i'm thinking :
Edelbrock #60439 performer RPM heads with the 100cc chamber. These should give me 9.4 CR
Comp 11-602-4 thumper cam (hyd flat tappet) 243 / 257 .522 / .507 107 LSA
single plane intake
850 holley
2" hooker headers
78 malibu with 4.10 gears, 3200 pounds, 4000 stall
Will this make 500 hp ? Maybe mid 11 's ?
Re: low buck 454
Mechanical flat tappet camshaft that does work with stock bbc rockers and is 500+ hp capable on a 454 w 10:1 cr
Crane F326-2 (Fireball 326) Crane # 134261
It works w single p lane or big dual plane or the bbc street tunnel ram too... Great street nitrous modest valve lift.
Use good dual springs
326-336 252-262 110 lsa 105/115 554"/.554" .532"/.530" net w lash .022/.024.. Lash varience allowed to tune for effect
Re: low buck 454
Another ,lower cost allows buying long slot rockers
Howards cam 121052-10
282-282 248-248 .578-.578" ..022-.022 lash
..556"/.556" net w lash
You can spring for new long slot rockers
or carefully grind and debur the slots in your stock rockers
for rocker slot/stud clearance.
Re: low buck 454
not bad . Not crazy about hyds on a bbc that you want to rev up.prairiehotrodder wrote: ↑Sat Jun 20, 2020 7:39 pm no solids
how about this :
https://www.lunatipower.com/bootlegger- ... 5-312.html
Re: low buck 454
if it goes down the track it would be my wife or son driving it. I don't want to have to touch anything on it. I allready have one race car to worry about.
Re: low buck 454
If I can learn how to set valve lash on a 454 some 45 years ago so can your son.. Use the cold set method EOIC.
Its pretty goof proof. set about .002"-.004" tighter than hot lash. If you spring for the low cost $$$Summt- SpeedPro Elgin hi perf long slot rockers really open the doors on off the shelf cams for this. Hyd or solid.
The 294s-10 magnum cam is not bad at all for this.
Set lash at .020"-.022" COLD and shut the hood for months.
Re: low buck 454
Here is a good one that will work with the stock rockers.
Yess another street strip solid.
Isky Z33 #396233 the catalog says .560" lift. this is with a 1.75:1 rocker arm..
Yours are 1.7 the gross lift is .544".
290-290 250/250° .320/.320" (lobe lift)
108 LSA
.030" hot lash (You can play with that on this one)
108 LSA
- af2
Re: low buck 454
That is why I posted the link. that piston is designed for the Edelbrock head and has the comp. height were he deeds it.
GURU is only a name.
Re: low buck 454
FWIW, I just got a cam from Mike (forum owner) and it is super sweet. You may want to consider having him make you a cam custom for your combo. I doubt you'd find a better cam.
Re: low buck 454
You are so right.. For the 110cc head, these specific pistons fit.
Re: low buck 454
F-bird - how about Lunati 30110513 ? I think you convinced me to get a solid.
243 / 251 .586 / .600 110 LSA 104 ICL
its just about impossible to find the type of cams i like to run for low buck street blaster style engines. I like a tight LSA, big duration (240 - 250 area) and low lift to be easy on parts. I've used the ISKY 396245 before with good results. But i'm trying to find something thats sitting on the shelf without having to special order or custom grind. I had a customer call me this morning wanting a Lunati cam so i figured since i'm placing an order i might as well get one from them for myself as well.
Brian
Brian
Re: low buck 454
also others have suggested a Jones cam or a Cos-cam. I feel like i would really like to try those but maybe someday when i'm building a serious engine that i can test them on the track and see how they compare against whatever else i might allready have. I do appreciate the suggestions though.
