Ignition curve discussion
GRTfast
Re: Ignition curve discussion
Post by GRTfast » Mon Jun 22, 2020 6:13 pm
PackardV8 wrote:
Mon Jun 22, 2020 5:17 pm
How did we get ten posts in without someone saying, "Just lock 'er in at 34 degrees and forget about all that initial and advance stuff."
:lol:
I tried a 38 everywhere setup, kinda bucked at low rpm steady speed. The map in it right now runs really well and is the smoothest driving setup I've had since the car has been on the road. Mike's cam has something to do with that as well.
novadude
Post by novadude » Tue Jun 23, 2020 9:16 am
Schurkey wrote:
Sun Jun 21, 2020 1:50 pm
GRTfast wrote:
Sun Jun 21, 2020 11:42 am
Is it the case that the engine would like more and more advance as the revs build, and the reason for not adding more advance after 3000 rpm or so is because you just run up against detonation? Just curious what you all think.
My understanding--from listening to other folks, not from my own independent research--is that there's no need for additional advance after a certain RPM. In fact, high-RPM use may need a few degrees of "high-speed ignition retard" because the in-cylinder turbulence becomes so much greater as the RPM builds. The turbulence speeds combustion.
I've heard that, but I've also seen smart guys make the case for a curve that gradually increases a few degrees above "max" advance as RPMs climb to counter the effects of slew rate in the module / coil.
hoffman900
Post by hoffman900 » Tue Jun 23, 2020 10:23 am
To be fair, it's all guess work without instrumentation.
David Redszus
Post by David Redszus » Wed Jun 24, 2020 10:26 am
Squish velocity, the main component of combustion turbulence, does increase proportionally to rpm.
Ignition delay, the time period from ignition to self-sustaining spark, is a function of time not degrees. Therefore we need more degrees as rpm increases.
The fastest flame speed usually is found at or very near the torque peak; we need slightly less timing.
Higher engine speeds allow less time for fuel evaporation, reducing mixture quality while requiring an increase in spark advance to maintain the same peak pressure angle.
The peak pressure angle will vary with engine speed and will need an adjustment in spark timing to optimize combustion timing.
When you out it all together, the ideal ignition curve becomes complex; somewhat like the Rocky Mountain Range.
Which is why ECU ignition maps provide the construction of complex curves, often different for each cylinder.
GRTfast
Post by GRTfast » Wed Jun 24, 2020 11:01 am
Makes sense. The optimal curve for our kart engines looked like a stock market chart.
Calypso
Post by Calypso » Wed Jun 24, 2020 1:00 pm
GRTfast wrote:
Sun Jun 21, 2020 1:52 pm
In our two stroke shifterkart engines, the curve for best wide open power was very advanced down low and got progressively more retarded through the rev range. Probably due to some form of the same phenomenon.
2-strokes retard at high rpm to put more heat into pipe, which changes the speed of sound to make pipe look shorter and stay in tune.
GRTfast
Post by GRTfast » Wed Jun 24, 2020 1:35 pm
That is certainly part of the equation. I know each different pipe had a different optimal curve.
David Redszus
Post by David Redszus » Wed Jun 24, 2020 8:35 pm
The fun part came when we found that a two stroke at constant throttle and rpm, would increase EGT with time.
Now it was time for the really sharp tuners to go have a beer. :lol:
hoffman900
Post by hoffman900 » Wed Jun 24, 2020 8:38 pm
Well, EGT sensors are thermal sensors, so isn't that always the case?
Calypso
Post by Calypso » Thu Jun 25, 2020 1:47 am
At speed or on the dyno?😊
