predicting cranking compression
David Redszus
Re: predicting cranking compression
Post by David Redszus » Thu Jun 25, 2020 2:00 pm
Nut124 wrote:
Thu Jun 25, 2020 8:28 am
tcb3274 wrote:
Thu Jun 25, 2020 7:15 am
What psi is considered ok for 93 octane? 200 psi?
Cranking compression is not a predictor of whether detonation is going to happen. A hot build will likely crank a lower PSI than a mild build with less CR.
Cranking compression pressure does not determine detonation or pre-ignition. Those are determined by
temperature, not pressure.
Increased compression pressure will raise chamber temperature prior to TDC. But other factors such as inlet ambient air temperature, intercooler efficiency, fuel evaporation cooling will determine the onset of combustion.
77cruiser
Post by 77cruiser » Thu Jun 25, 2020 3:01 pm
Stan Weiss wrote:
Thu Jun 25, 2020 12:57 pm
Jim,
I don't have anything for start RPM in my software and it use IVC at the seat. What I get working backward for you engine and 181.9 psi.
Is IVC 70.35 ABDC and with a 103 ICL that is 294.7 seat_to_seat duration.
Stan
First 2 is my cam seat & .05.
Jim
Stan Weiss
Post by Stan Weiss » Thu Jun 25, 2020 4:30 pm
Jim,
Stan
Jim,
So what did you get when you did a cranking compression test? Based on your engine specs and that those cam specs I get 196 PSI.
Stan
Stan Weiss / World Wide Enterprises
Do you use engine simulation software that uses cylinder head flow files?
We have a package of more than 3025 DFW or FLW Files
swampbuggy
Post by swampbuggy » Thu Jun 25, 2020 5:38 pm
OK Mark G. now tell us how many Degrees After Bottom Dead Center the Intake Valve Seats ? with normal running lash of course. Mark H.
77cruiser
Post by 77cruiser » Thu Jun 25, 2020 9:45 pm
Jim,
Stan
Jim,
Stan
I think it was about 185 cold.
Jim
mt-engines
Post by mt-engines » Fri Jun 26, 2020 8:48 pm
Coloradoracer wrote:
Thu Jun 25, 2020 8:37 am
Case in point, my stuff......static compression ratio is 16.5:1....cranking compression is about 180 psi......According to the dyno, I make 1510 hp @ 7100 rpm, no nitrous.....that was on gasoline. I've since switched to methanol, and it definitely made a difference...would love to dyno it again...
Wow. How many cubic inches?
