predicting cranking compression
David Redszus
Re: predicting cranking compression
Post by David Redszus »
Nut124 wrote: Thu Jun 25, 2020 8:28 am
tcb3274 wrote: Thu Jun 25, 2020 7:15 am What psi is considered ok for 93 octane? 200 psi?
Cranking compression is not a predictor of whether detonation is going to happen. A hot build will likely crank a lower PSI than a mild build with less CR.
Cranking compression pressure does not determine detonation or pre-ignition. Those are determined by
temperature, not pressure.
Increased compression pressure will raise chamber temperature prior to TDC. But other factors such as inlet ambient air temperature, intercooler efficiency, fuel evaporation cooling will determine the onset of combustion.
77cruiser
Post by 77cruiser »
Stan Weiss wrote: Thu Jun 25, 2020 12:57 pm Jim,
I don't have anything for start RPM in my software and it use IVC at the seat. What I get working backward for you engine and 181.9 psi.
Is IVC 70.35 ABDC and with a 103 ICL that is 294.7 seat_to_seat duration.
First 2 is my cam seat & .05.
Jim
Stan Weiss
Post by Stan Weiss »
77cruiser wrote: Thu Jun 25, 2020 3:01 pm
Jim,
So what did you get when you did a cranking compression test? Based on your engine specs and that those cam specs I get 196 PSI.
swampbuggy
Post by swampbuggy »
OK Mark G. now tell us how many Degrees After Bottom Dead Center the Intake Valve Seats ? with normal running lash of course. Mark H.
77cruiser
Post by 77cruiser »
Stan Weiss wrote: Thu Jun 25, 2020 4:30 pm
Jim,
I think it was about 185 cold.
Jim
mt-engines
Post by mt-engines »
Coloradoracer wrote: Thu Jun 25, 2020 8:37 am
Case in point, my stuff......static compression ratio is 16.5:1....cranking compression is about 180 psi......According to the dyno, I make 1510 hp @ 7100 rpm, no nitrous.....that was on gasoline. I've since switched to methanol, and it definitely made a difference...would love to dyno it again...
Wow. How many cubic inches?
Alaskaracer
Post by Alaskaracer »
665", 12* Chevy....
intake opens 24, closes 86
exhaust opens 74, closes 36
These are .050" numbers....
Mark Goulette
Authorized Amsoil Retailer
David Redszus
Jim,
Stan,
You might want to remind folks that calculated pressures are often in units of psia while measured pressures are in
units of psig.
Stan Weiss
David Redszus wrote: Tue Jul 07, 2020 10:33 am
Jim,
Stan,
units of psig.
David,
Way back my MD-DOS software calculated psig. When I rewrote my software for Windows I screwed up and calculated psia. Not long after that I realized my mistake and ever since then the user can calculate either psig or psia depended on which button they click.
Also I am not sure how many people understand that and how a change in BP or temperature effects cranking compression.
Post by pdq67 »
Very interesting thread, but I am more interested in dynamic compression ratio, (DCR), than static compression ratio, (SCR).
If not mistaken, it is a better predictor of fuel detonation.
And rod length does enter in here, but not to a great extent.
Please correct me if I am wrong.
And not meaning to hi-jack the tread.
af2
Post by af2 »
pdq67 wrote: Tue Jul 07, 2020 10:39 pm Very interesting thread, but I am more interested in dynamic compression ratio, (DCR), than static compression ratio, (SCR).
Nope!
And I ave to quote another.
GURU is only a name.
af2
Post by af2 »
Jim,
Stan,
units of psig.
To Paul again
Stan Weiss
I don't know how others do their calculation of cranking compression pressure. But for me one of steps along the way is the calculate DCR or as some call it trapped compression ratio.
af2
Post by af2 »
Stan Weiss wrote: Tue Jul 07, 2020 11:03 pm I don't know how others do their calculation of cranking compression pressure. But for me one of steps along the way is the calculate DCR or as some call it trapped compression ratio.
When we figure it out then every strain of valve size and combustion chamber and intake will have a perfect #?????? Oh And Cam!
af2
Post by af2 »
Predicting ring flutter is way more ..... what can I say?
